can you use a p08 for a mini me swap
Old Dec 15, 2004 | 11:19 AM
dblock91's Avatar
Default can you use a p08 for a mini me swap
i know some one with an obd1 p08 computer and i was wondering if it was the same as using a p28 computer
Old Dec 15, 2004 | 11:23 AM
DJ_SaNdOz's Avatar
Default Re: can you use a p08 for a mini me swap (dblock91)
Yes you can, but IMO a P28 would be slightly safer b/c the P28 has less timing & more fuel which may be required due to teh increased compression of a mini me, but I am sure that the P08 will work.
Edit: also be aware that a P08 looks for a different O2 than the P28
Old Dec 15, 2004 | 11:40 AM
fourthgenhatchB17's Avatar
Default Re: can you use a p08 for a mini me swap (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">
Edit: also be aware that a P08 looks for a different O2 than the P28</TD></TR></TABLE>
PO8 looks for a single wire O2. P28 looks for a 4 wire. U can still use the PO8 with the 4 wire though.
Old Dec 16, 2004 | 08:15 AM
dblock91's Avatar
Default Re: can you use a p08 for a mini me swap (fourthgenhatchB17)
the mini me is on a 91 dx, with a 93 head , i need to get a wire conversion. i think im gonna just spend the extra cash and get a p28, rather than going cheap. What did you mean by p28 looks for 4 wire
thanks for the help
Old Dec 16, 2004 | 02:30 PM
P28 ecu needs to have a 4 wire O2.
Old Feb 3, 2005 | 05:58 PM
dblock91's Avatar
got the jumper harness and p28, im set
l1bid0
Apr 15, 2007 05:43 PM
zenon8890
Dec 9, 2006 01:37 PM
1990hondaHF
11
Aug 21, 2003 09:29 AM
hYbRiD EeEkAy
Aug 16, 2003 10:51 PM
SprayinCX
Apr 12, 2003 08:45 AM
