How to fix the Headlight/Turn Signal Gap on a 4G?
Old Jan 3, 2002 | 08:08 PM
IAIA's Avatar
Default How to fix the Headlight/Turn Signal Gap on a 4G?
My Passender Side Lights are ok but I notice my Drivers Side one has a gap big enough that I can stick my pinky between them, it's a tight fit, but it will still go. I never noticed it before I had my accident so i may have messed it up from that.
So how can I fix this, can I bend something back, or is my frame or something ****ed?
I think I know what it is, it's the metal thing that holds the housing from the top, if I could bend that back it would fix the gap, but is it possible to bend back? Could I do it with a Crowbar? Or is my car a Bodyshop candidate...
Old Jan 3, 2002 | 10:13 PM
Magick211's Avatar
Default Re: How to fix the Headlight/Turn Signal Gap on a 4G? (IAIA)
I have the same problem
Old Jan 6, 2002 | 05:03 PM
IAIA's Avatar
Default Re: How to fix the Headlight/Turn Signal Gap on a 4G? (CivicBoyZC)
Would you like to know how to fix it?
Old Jan 6, 2002 | 05:07 PM
gambit023's Avatar
if your talking about the 88-91 models, try pulling out the corner lens and then put them back in, but this time double check that the corner lens slides into it's slot. if that dosen't work just push it straight with force.
Veency
Lighting
Jul 14, 2016 01:46 AM
mlong01
Audio / Security / Video
Jul 17, 2007 05:30 PM
Thanks knightsport!
Dec 27, 2005 11:38 AM
CrazieLude
Jun 20, 2003 09:58 PM
