Sheared a tooth off my power enterprise belt
Old Dec 14, 2004 | 11:18 PM
43MA's Avatar
Default Sheared a tooth off my power enterprise belt
two hours and i'm left with this
sweet... check out the perfect imprint of my exhaust valves
another pic. notice the corrosion on my block
this is supposed to be attached to my t-belt
nothing is impervious to the rath of Toda B's
Old Dec 15, 2004 | 12:09 AM
Supernatural's Avatar
Default Re: Sheared a tooth off my power enterprise belt (Steady)
those belts are ****** overated.....ive seen more of those **** people **** up then stock belts.....sorry man....
Old Dec 15, 2004 | 12:22 AM
ceLtic's Avatar
N/A wh0re!
Default Re: Sheared a tooth off my power enterprise belt (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">those belts are ****** overated.....ive seen more of those **** people **** up then stock belts.....sorry man....</TD></TR></TABLE>
yep. **** those belts. OEM &gt; *
Old Dec 15, 2004 | 12:32 AM
ArinX's Avatar
kinda feel the same way
Old Dec 15, 2004 | 01:33 AM
Phoenix1's Avatar
Eeesh...sorry to see that...
What belt would you all recommed for big cams + 9500 rpms, all motor?
Old Dec 15, 2004 | 03:59 AM
Chillinit's Avatar
Default Re: (RA004E)
OEM!
Old Dec 15, 2004 | 04:43 AM
1 2 NV's Avatar
couldnt have said it better myself bell. toda, PE, and others
OEM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RA004E &raquo;</TD></TR><TR><TD CLASS="quote">Eeesh...sorry to see that...
What belt would you all recommed for big cams + 9500 rpms, all motor?</TD></TR></TABLE>
OEM
Old Dec 15, 2004 | 04:52 AM
Dan GSR's Avatar
Default Re: Sheared a tooth off my power enterprise belt (1 2 NV)
how long did that PE belt last?
what do you guys reccomend as far as mileage before replacing an OEM belt with big cams such as toda C's
Old Dec 15, 2004 | 05:04 AM
1 2 NV's Avatar
Default Re: Sheared a tooth off my power enterprise belt (Dan GSR)
i only had 9k on my car b4 the motor got built and put into another car. someone else will have to take this question on.
Old Dec 15, 2004 | 05:43 AM
rhd's Avatar
rhd
the belts are TOO stiff/tight. the OE belts are MORE than strong enough for any setup...and they have the right amount of "give" in them to keep from this stuff happening
and most of the ppl you see kill belts, have them WAY too tight
Old Dec 15, 2004 | 07:35 AM
JerseySiPOS's Avatar
Default Re: (rhd)
sorry to hear that man. even tensioned properly, i just dont trust the OEM belts for Toda B cams.
i just dont think anyone with stock cams can say OEM is the best for big cams.
Although a couple ppl here posted that they use an OEM belt for their big cams.
This is the first time ive seen a tooth sheered off of a PE belt.
Ive been running the Toda belt and it flaps, thats how its supposed to be tensioned.
JMO
Old Dec 15, 2004 | 07:40 AM
one_c18b's Avatar
man, thats weird... i was about to jump on this belt, but i decided to go oem with my motor..
sorry to hear that
Old Dec 15, 2004 | 08:13 AM
Ketone's Avatar
Default Re: (one_c18b)
sorr to see that! How long was the belt on for?
Old Dec 15, 2004 | 08:46 AM
Black R's Avatar
25 Year Member
how many miles on the belt?
how tight was it tensioned and how long ago?
when was your last valve lash adjustment?
do you run an uncut valve cover?
Old Dec 15, 2004 | 09:57 AM
Default Re: Sheared a tooth off my power enterprise belt (Black R)
i would say as long as you turn the crank counterclockwise about 1 tooth and just before the exhaust cam gear moves, you should be alright. that way on cold starts the belt will flap with even tension between the cam pullies and under the exhaust cam gear.
but things do go wrong for certain ppl sometimes
Old Dec 15, 2004 | 11:22 AM
Default Re: Sheared a tooth off my power enterprise belt (blackstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackstar &raquo;</TD></TR><TR><TD CLASS="quote">ah crap! i'm glad i saw this before i used my PE belt. but is the OEM one really gonna handle buddy club 4's with TWMs?? all i need is to worry about snapping a timing belt</TD></TR></TABLE>
you can use an OEM belt, but i personally would use PE or toda. If your not sure on the tension, take to someone who has ran both belts with big cams.
Old Dec 15, 2004 | 12:14 PM
rhd's Avatar
rhd
Default Re: (JerseySiPOS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerseySiPOS &raquo;</TD></TR><TR><TD CLASS="quote">sorry to hear that man. even tensioned properly, i just dont trust the OEM belts for Toda B cams.
JMO</TD></TR></TABLE>
i'm rinning bigger cams than 99.9% of street hondas.....and i'm running an oe belt.
Old Dec 15, 2004 | 12:35 PM
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">
i'm rinning bigger cams than 99.9% of street hondas.....and i'm running an oe belt.</TD></TR></TABLE>
as long as it works for you, thats good. i usually like to base my opinions off of my own experiences.
Old Dec 15, 2004 | 12:46 PM
G U E C O's Avatar
damn
Old Dec 15, 2004 | 03:29 PM
1 2 NV's Avatar
Default Re: (rhd)
i guarantee i run my belt tighter than 99.9% of these guys on this board and beyond. my belts have never failed and as i said in my earlier post its an OEM belt. i would never even think about goin with PE or TODA. both are junk.
ive seen OEM break, but i see these guys with built motors that run PE or TODA and seen them loose a 5K+ motor because of those belts.
seems as though the belts loose teeth as in this case or ive seen them just start to crack at the teeth which is just a matter of time b4 it looses that tooth. once again OEM PE/TODA junk junk junk
Old Dec 15, 2004 | 06:39 PM
43MA's Avatar
belt has about 40KM or 25Miles. it is no older then two years old with some track abuse.
car ran with cut valve cover
the overall condition of the motor is pretty
compression is 250 even all across
plugs show good burn
passed goverment emissions testings with stock cat
i'm a little undecided on what to do now.
toda's seem to have a statistically higher chance of demolising belts.
i'm thinking of going to something with a more mild primaries like jun 3's
Old Dec 15, 2004 | 06:46 PM
Dan GSR's Avatar
40 KM
or
40,000 KM ?
Old Dec 15, 2004 | 07:08 PM
revvin9k's Avatar
Toda.
Old Dec 15, 2004 | 08:12 PM
Big Teggie's Avatar
Default Re: (S(J)O(D)L(M))
I have always used OEM belts on all of my motors. With ITR, CTR, Skunk2, and RLZ cams, I have never encountered any problems. Just keep proper tension on the belt and dont use an old *** belt.
Old Dec 15, 2004 | 08:18 PM
43MA's Avatar
40000km
