CRX seat swap /upgrade info
Is it possible to take a passenger side seat and putting it on the drivers side with the right work? if so is it hard to do? i cant seem to find a decent driver side seat so i figured i would see if its possible. any info would be appreciated. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18apwr »</TD></TR><TR><TD CLASS="quote">Yep. What he said. ^^
And you stole my avatar - loser.</TD></TR></TABLE>
too many people have that damn avatar. Same with that damn chick in teh white wifebeater.
I ahve always wondered about this swap as well, so I'm posting to subscribe.
mine arent torn, but the passenger seat's bolsters are firmer...someone that has done this, post!. It seems impossible. Im about to put the hog rings back in and say to hell with it
I swapped ALL the foams from the passenger side to the driver side and the upper fabric on my Si seats. I didn't use hog rings to put it all back together, I used big zip ties - they work VERY well and were easy to install.
On the foam swap, the uppers work fine, the lower seat pan foams have to be trimmed just a little around the seat tilt adjuster. After making that small change, the swap worked fine.
i have a hog ring tool that I'll try using. i did it gsr seats into the rear of an ek and used zip ties though, so may resort to that if neccesary. You took the foam and evrtyhing right off the skeleton? I dont know if i wanan do that..seems it would slide around or something...since they arent ripped and just aren as firm, maybe ill go to the reupholstering shop in town and see if i can get some foam or something
essentially your not swappin seat pans, but the foam and cloth instead? Arent there two holes on the side of the bottom cushion and 1 on the other?cut a new hole?
civicflow
11
Mar 6, 2005 06:18 PM
1whitedc2
Jan 24, 2005 03:35 PM
