Preventing rust on rear fenders in wheel well
Just like the topic, I read on here just a little bit ago that removing the liners on the rear fenders of civics/hondas can help prevent the rust. I live in Ohio, the ultimate in freeze/thaw and salt use state...
I wonder if its true, because if it were true, wouldn't it be cheaper for honda to leave it off?
Anyways, should I remove these rubber liners around the inside of my rear fender lips? Kind of makes sense to me since I've been watching the ends of it come off on its own, I kept having to put it back on.
Aside from that, how many times would you suggest I use a self serve drive in cleaner's water pressure washer to spray the underside of my car?
the rear liners are the problem, honda tried to make the rear fender protect itself from the elements but what they forgot to think about what the fact that condensation can get in the little areas and if it sits there too long...taaa daaaa you have yourself a nice "honda rust spot". I took mine out first day i got my car
thank you both, I kind of thought that for over a year, but thought... why would honda do that? I guess I forgot, if honda was thinking, the b16 would have been stock, an icebox would be the intake, the body would have full suspension support, the rear subframe would be straight across to support a rear sway bar on all models
go free improvements and tuning lol
When we bought my girls '99 EX sedan it had 63K and the rear fender lip protectors were seperating at the ends. I just did the same thing I did with my '98 Subaru Legacy L wagon taht came with the protectors. I took them off, cleaned the rear fenders lips inside and out with rubbing alchool. Then I cheaked the lips for any scratches nicks or rust. I only foun one spot near the rear of teh fender where a rock had chiped the paint. Everything under the protector was CLEAN of anything. I got some good 3M weatehr strip adhesive. I reinstated the protectors and put small wood working clamps on the ends to keep then air tight and sealed! The main purpose of the protectors is to stop stone chips on the rear fender lip. They dod a good job. The stock way of instaling them is cheap and that is how ther seperate from the factory and start leting mostuire and salt and debris in. I say clean and cheak the surface of the rear fender lips when the stock adhesive lets loose and reinstal them right!
"how many times would you suggest I use a self serve drive in cleaner's water pressure washer to spray the underside of my car?" Raod salt is activated (starts becoming caustic) ABOVE 32 degrees. Sooooo, if tehre is road salt on your car and it is under 32 degrees and it is not in a garage you are fine. When teh temp gets above 32 for any amount of time I spray the under body with a pressure wand for $1.00 at the local car wash. No rust in a '93 Toyota Corolla wagon with 300K all it's years in the salt Northeast!!
I do RUN THE WAND QUICKLY OVER THE OUTSIDE OF THE CAR just to get the salt off. But I mainly focus on the under body that is where teh salt sits on bare or un painted metal and does damage. I give the outer skin a good coat of Newfinish acylic wax before the winter comes, and make sure all nicks and scratches are atleast primed!! The outer skin hols up pretty well if waxed, it's the under body that takes a beating!!! It is going to look like crap during the winter anyways why ice my doors shut!!
Are you talking about the lining that is DIRECTLY above the rear wheels? Could someone post a picture of the linings you guys are talking about? Thanks.
No pic, but I'm gonna describe it, it is the rubbery black strip, that fits on the lip that is bent in towards the trunk, on the edge by the wheels.... the same spot people roll when they have too wide of tires and drop the car.
If you already have rust there take them off imediately!! Treat the rust with Exend or Navel Gelly, then prime and paint. Rubb the lips down with achool and reinstall the strips after teh paint has dried.
My car is a 2000 Civic and I took off the lining in summer of 2003. I wash my car regularly and I remember that night, my friends told me to take it off cause of rust and whatnot will build up in there.
2 hours before I met up with them, I had just washed my car at home. When I took off the lining, I rubbed the inside with tissue and a huge handful of black colour dirt and whatnot came out. It was disgusting. There goes a 3 years of road debris build up.
Ever since that day, everytime I wash my car, I rub the inside with my hand until I feel bare metal - weather I wash the car at home or at the coin-op during winter time.
And as for how salt works, like someone mentioned earlier, it works when the salt water is in liquid form, meaning, abouve 0 C /32 F. When the salt on your car is all frozen, it won't do anything because there is no moisture on the car, only solid particals.
But I still wash my car once a week.
You are very right salt is only active above 32 degrees F. I just make sure I wash UP BEHIND THE PROTECTIVE STRIP ON BOTH MY CARS every time I was it at teh coin-op when it gets above 32 like today. Just came back from doing it on my lunch break!!
Joel
Joel
go look at your car, you can tell, look at the rounded lip around the wheel... the part of the metal right above the tire, cut in a curve... Everyone with me here?
On that edge, feel it, feel for rubber, that is black, it goes all the way along that edge.. that is what we are talking about, it takes a few lbs of force to pull it all off in one big peice, its oh... 2-3 feet long id say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. »</TD></TR><TR><TD CLASS="quote">Yea, can someone take a picture of this???</TD></TR></TABLE>
