Retainers and dimensions
Old Dec 14, 2004 | 08:19 PM
Dan GSR's Avatar
Default Retainers and dimensions
I need to find a retainer to fit my eibach valve springs
this is a diagram of a retainer
I measured with a caliper, and
I need:
A: 1.15
B: 0.85
C: 0.66
I measured a portflow retainer I have to be:
A: 1.1035
B: 0.857
C: 0.6080
I measured a stock retainer:
A: 1.1035
B: 0.857
C: 0.6080
looks like portflow is modeled after a stock retainer
Crower, according to their website
A: 1.150
B: 8.70
C: 6.10
anyone have any more measurements?
JG?
Skunk 2 ?
rocket ?
anything else im missing?
***** EDIT ********
(thanks to Tbone)
Rocket Motorsports gen 1
A: 1.112
B: .848
C: .613
All measured with a digital caliper.
Modified by Dan GSR at 8:16 AM 12/15/2004
Old Dec 14, 2004 | 08:25 PM
Suprdave's Avatar
Default Re: Retainers and dimensions (Dan GSR)
What does Eibach recommend?
Old Dec 14, 2004 | 08:31 PM
Dan GSR's Avatar
Default Re: Retainers and dimensions (Suprdave)
they are clueless, all they said was its compatible with OEM
Old Dec 14, 2004 | 08:34 PM
DOHCtorTHRUST's Avatar
i forgot who it was that works at eiback, hes a member here on H-T... you could search around and then PM him, im sure he will be more then willing to help you as he is very knowledgeable...
Old Dec 14, 2004 | 08:37 PM
Dan GSR's Avatar
Crower also sells a valve spring that is made by Eibach, with the same dimensions as my spring, with a different spring rate, and crower recommends their own retainer
Old Dec 14, 2004 | 08:38 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">i forgot who it was that works at eiback, hes a member here on H-T... you could search around and then PM him, im sure he will be more then willing to help you as he is very knowledgeable...
vtecvoodoo
I messaged him a while back, but wasn't able to give me much insight
Old Dec 14, 2004 | 08:53 PM
Tbone's Avatar
A: 1.112
B: .848
C: .613
Old Dec 15, 2004 | 04:17 AM
Dan GSR's Avatar
Default Re: Retainers and dimensions (Tbone)
thanks
seems like my problem is dimension "C"
my ID is a lot bigger than most retainers
anyone know where i might be able to get a retainer made for my needs?
Old Dec 15, 2004 | 09:30 AM
SkRiBLaH's Avatar
vtecvoodoo works for them
Old Dec 15, 2004 | 09:47 AM
vtecvoodoo's Avatar
Future Texas Boy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">Crower also sells a valve spring that is made by Eibach, with the same dimensions as my spring, with a different spring rate, and crower recommends their own retainer</TD></TR></TABLE>
Wrong. We do not make their springs.
I`d use the Portflows or Crower.
Old Dec 15, 2004 | 10:58 AM
Dan GSR's Avatar
Default Re: Retainers and dimensions (vtecvoodoo)
http://crower.com/cat/import/h...shtml
seems that most of them are Crower
but part number 68186 is labeled as Eibach B Series VTEC Dual Spring
the portflow fits the out spring nicely
but the the inner spring is so loose on the retainer that it can move around A LOT
Old Dec 15, 2004 | 12:17 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">
I`d use the Portflows or Crower.</TD></TR></TABLE>
He never said you did.
So Eibach doesn't recommend anything? The springs are made specifically for stock retainers?
You would use Portflow or Crower over stick or you would use one of the two if you went aftermarket?
Old Dec 15, 2004 | 12:37 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Retainers and dimensions (EKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">
He edited the post.
I wouldn`t use stock. If the head was off, and I was upgradng springs, I would go aftermarket. Used both Portflow and Crower in the past and with positive experiences.
Old Dec 21, 2004 | 02:08 PM
Rocket's Avatar
You'll need custom made. Contact JG.
Old Dec 21, 2004 | 05:16 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Retainers and dimensions (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">You'll need custom made. Contact JG.</TD></TR></TABLE>
Really? Wow.
all-mtr-teg
Sep 10, 2009 06:50 PM
dc4teg95
Jun 9, 2008 04:18 PM
CustomX113
Dec 21, 2006 12:29 PM
FROSTDC2
17
Oct 30, 2005 05:58 AM
Q-OnE
Dec 12, 2002 10:41 AM
