bouncing engine temp needle
Old Dec 14, 2004 | 07:04 PM
NorthernXposure's Avatar
Default bouncing engine temp needle
as the title reads... my engine temp needle is bouning between cold and normal operating temp... and i mean literally bouncing.. not a gradual sweep. could this be a sign of a bad themostat or an ecu problem? the motor is a built b18c5... im not too sure but it may or may not have a spoon T-stat... my brother and his shop built the motor so im not totally familiar with all the parts used for the build up... thanx for any info in advance fellas
Old Dec 15, 2004 | 04:55 AM
JimBlake's Avatar
Default Re: bouncing engine temp needle (NorthernXposure)
It's jumping too quickly to be a TRUE temperature change, right? So it wouldn't be the thermostat.
That gauge circuit has nothing to do with the ECU...
Look at the connection at the temperature sender. It's the small 1-wire sender near the upper radiator hose in the head. I think it would go cold if it's unplugged, so a loose connection would jump between cold & true. If it's OK out there, look for a loose connection at the cluster. I don't know if there's a plug somewhere in between??
Old Dec 15, 2004 | 07:53 AM
West Werks's Avatar
Also check for air in the system and the seal on the radiator cap. It has happened to me and it was air in the coolant system due to a bad seal on the cap....
Old Dec 15, 2004 | 08:34 AM
dohcter g's Avatar
Default Re: bouncing engine temp needle (VenGeanceDrag)
Replace the Temp Gage mechanism in the cluster!!!
projekt90ef
Jan 19, 2010 03:43 PM
neoc03
Apr 15, 2008 09:49 AM
213374U
Jul 31, 2007 05:49 PM
NorthernXposure
Dec 16, 2004 04:51 AM
TypeR509
May 12, 2003 03:36 PM
