Car dies when cold
Old Dec 14, 2004 | 06:19 PM
eL's Avatar
eL
Default Car dies when cold
Well, If I don't warm up my car and I try to drive immediately after turning it on, It will just cut right off. If it doesnt shut off the RPMs will drop extremely low then go back up to idle.
This car also has a bouncing idle problem when warm. So when the engine is really cold and I hit the gas the engine dies. When warm there is an idling issue. Any help? I tried replacing the IACV and I cleaning it as well.
b16a2.
Old Dec 14, 2004 | 06:20 PM
gamby's Avatar
Default Re: Car dies when cold (eL)
My wife's CR-V had a silmilar problem. Stalled during the first few minutes of driving. Weirdest thing fixed it--a valve adjustment solved the whole problem.
Give it a shot (assuming it hasn't been done to the car recently).
Old Dec 14, 2004 | 06:22 PM
eL's Avatar
eL
A valve adjustment fixed the cold problem? That's weird. Did the car have any idling issues?
Old Dec 14, 2004 | 06:24 PM
Ricey McRicerton's Avatar
Default Re: (eL)
Cold idle thermo valve?
eL's Avatar
eL
Explain my friend.
Old Dec 14, 2004 | 06:28 PM
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Explain my friend.</TD></TR></TABLE>
Doubt it'd do the same thing, but when I did my intake mani swap, they talked about a sensor that coolant runs through on the TB of the Y7 that is used to control cold idle. I *think* if you just loop and bypass it, the car idles higher than normal. Guess it's not really going to solve your problem, but it sounded good in my head.
Old Dec 14, 2004 | 06:30 PM
eL's Avatar
eL
Thanks for tryin
My idle is already too high [usually sits at like 1300rpm]
Its really annoying to see my lights dim when the RPMs drop everytime I just hit the gas when its cold.
Old Dec 14, 2004 | 06:55 PM
gamby's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">A valve adjustment fixed the cold problem? That's weird. Did the car have any idling issues?</TD></TR></TABLE>
I know--even the mechanic said it was the last thing he would have suspected.
On cold starts, the car would stall out (especially on hills where the auto tranny was loaded a bit) or hesitate massively when it was just getting moving.
Basically, it would bog a bit coming out of the driveway. There is then a big hill to get out of my neighborhood. Stop at the top of the hill, car dies.
Once it was warmed up completely, it was fine.
The valve adjustment solved the problem completely. 100k on the clock and it feels like like new.
Old Dec 15, 2004 | 10:13 AM
SweetSol's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Cold idle thermo valve?</TD></TR></TABLE>
This guy is right.
It is your cold idle control valve. I had the same problem as you. Replaced it, now my car runs just fine in the cold.
Old Dec 15, 2004 | 12:43 PM
komat's Avatar
Default Re: (SweetSol)
how much does it cost avg for a vavle adjustment on a 94 civic cx?
Old Dec 15, 2004 | 01:25 PM
SweetSol's Avatar
Default Re: (komat)
Around 80 bucks.
Old Jan 19, 2005 | 01:13 AM
eL's Avatar
eL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SweetSol &raquo;</TD></TR><TR><TD CLASS="quote">
This guy is right.
It is your cold idle control valve. I had the same problem as you. Replaced it, now my car runs just fine in the cold.</TD></TR></TABLE>
that's not the IACV is it? if not, where is it?
kim_performance
Honda CR-V & Element
16
Mar 10, 2019 04:43 AM
aj116
Apr 19, 2009 12:17 PM
SOHCD16y8
Mar 5, 2006 06:47 PM
DrewDown
Jan 1, 2005 03:45 PM
13link EG
Oct 20, 2004 07:37 PM
