Accord "95 antenna problem. It wouldnt go all the way up, makes grinding noise.
Old Dec 14, 2004 | 05:38 PM
r3000's Avatar
Default Accord "95 antenna problem. It wouldnt go all the way up, makes grinding noise.
Today in the morning i noticed that when i turn on the radio (stock), the antenna in my 95 accord LX doesn't go all the way up, instead it freezes at half way point and smth (the motor?) makes grinding noise, but it does go inside (with grinding noise at the end). I couldn't find on google pictured replacement instructions. I checked ebay, the stock antenna (with the motor) runs ~40$ shipped. Any tips, links from you guys? May be i don't need the whole antenna replaced?
Thanks. Your help is appreciated.
Old Dec 14, 2004 | 06:33 PM
jwogen1's Avatar
Default Re: Accord "95 antenna problem. It wouldnt go all the way up, makes grinding noise. (r3000)
You need to replace the entire antenna actuator in the trunk/quarter panel...its an easy diy...or you can go with the S2000 antenna swap
Old Dec 14, 2004 | 06:51 PM
r3000's Avatar
Default Re: Accord "95 antenna problem. It wouldnt go all the way up, makes grinding noise. (jwogen1)
does it fit easily? Is it motorized also? I've checked on ebay, there are few kinds of s2000 antennas in the range 20-30$. Here is one:
Is it gonna fit my 95' accord?
Old Dec 14, 2004 | 06:56 PM
r3000's Avatar
here are few more:
Which one? What do you guys think??
Old Dec 15, 2004 | 04:48 PM
Cliffjumper2's Avatar
you don't need a new antenna or anything.
Last night was the coldest night in nyc this season; your antenna was just frozen. Let the car sit in the sun for a while, after making sure to have lowered the antenna all the way when you shut the radio off even if you have to lower it with your hand after turning off the car.
The next time you turn on your radio, it should go up fine....and tomorrow morning, just play the cd for a while till it heats up a bit
Old Dec 15, 2004 | 07:24 PM
NiBlazed's Avatar
Default Re: Accord "95 antenna problem. It wouldnt go all the way up, makes grinding noise. (Cliffjumper2)
Yea the antenna on my 95 been doing this lately, im in the bronx and yea its been freezing
mxteam
Aug 10, 2007 09:20 AM
dustay22
Mar 1, 2007 06:46 AM
jonzel
Mar 13, 2006 02:08 PM
shivsharma6
Apr 16, 2004 05:39 PM
RAiMA
May 28, 2003 02:14 AM
