charge pipes
Old Dec 14, 2004 | 04:17 PM
justinau's Avatar
Default charge pipes
what is sumething good and cheap and easy to use for charge piping
Old Dec 14, 2004 | 04:22 PM
HumanResource's Avatar
Default Re: charge pipes (justinau)
Aerosol Cans
Old Dec 14, 2004 | 05:06 PM
Skunk.Werks's Avatar
Default Re: charge pipes (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">Aerosol Cans </TD></TR></TABLE>
If you don't have anything constructive to say don't post.
I've heard of people using all sorts of stuff from PVC to various forms of plastic/rubber flex tubing. If you don't care about being super ghetto, any form of piping that is 2.5" to 3" that will be heat resistant. If you want to do it the right way, go search http://www.kteller.com which supplies pre bent tubing for your turbo applications.
Old Dec 14, 2004 | 05:10 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: charge pipes (Skunk.Werkz)
How about flex hose?
Old Dec 14, 2004 | 05:17 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinau &raquo;</TD></TR><TR><TD CLASS="quote">what is sumething good and cheap and easy to use for charge piping</TD></TR></TABLE>
check out the Forced Induction forum...
use the search button like no other and I bet you come up with some good stuff.
Old Dec 14, 2004 | 05:19 PM
Curtis2kul's Avatar
Default Re: charge pipes (Smokinsax)
ive heard you could use pvc after the intercooler to the intake manifold but from the turbo to the intercooler it would be best to use steel. i mocked my setup with pvc pipe then took that to the muffler shop and had them bend me a peice to match it!
Old Dec 14, 2004 | 08:13 PM
mrspeaker's Avatar
Default Re: charge pipes (Curtis2kul)
A bunch of 90 degree bends and some stright pipes from JCwhitney.com
They're not that expensive..
john d
Jan 24, 2005 01:58 PM
RACEPAK
Welding / Fabrication
20
Nov 13, 2004 07:27 PM
iwouldHITit
Jun 27, 2004 08:06 AM
Doctor CorteZ
Oct 4, 2003 02:03 PM
boostedsi1
Aug 6, 2003 09:06 AM
