High flo Cat
Old Dec 14, 2004 | 02:35 PM
ThaCivicAssassin's Avatar
Default High flo Cat
Ok Cheap gimic or money well spent?
Old Dec 14, 2004 | 02:37 PM
Kamin's Avatar
Default Re: High flo Cat (ThaCivicAssassin)
a normal catalytic converter, if clean, dosent hinder flow that much. BUT if you upgrade the exhaust to a larger size its a very good investment to get a larger diameter high flow cat.
Old Dec 14, 2004 | 02:39 PM
civictildeath's Avatar
Default Re: High flo Cat (Kamin)
love mine definately added power
Old Dec 14, 2004 | 02:41 PM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaCivicAssassin &raquo;</TD></TR><TR><TD CLASS="quote">Ok Cheap gimic or money well spent?</TD></TR></TABLE>
It all depends on what you're running on the exhaust path. If it's matched to the same size as your exhaust it's a great way to help the exhaust flow.
Make sure you only do this on 95 and older cars as they aren't OBDII legal.
Old Dec 14, 2004 | 02:48 PM
Kamin's Avatar
Default Re: High flo Cat (Spade)
there ARE obdII legal high flow cats out there. just hard to find.
Old Dec 14, 2004 | 03:17 PM
B16aDasher's Avatar
Are these obdII legal?
http://supremeperformance.com/...id=10
Old Dec 14, 2004 | 03:21 PM
Kamin's Avatar
Default Re: High flo Cat (B16aDasher)
Yes, see how it says EPA OBDII and ARB compliant?
Old Dec 14, 2004 | 03:22 PM
civiccpedx's Avatar
high flow cats are a good investment, they save you a ticket and still increase power.
Old Dec 14, 2004 | 03:55 PM
Sour Diesel's Avatar
If you're going to get one, do it right and don't get the cheap ones off ebay. I bet they will fall aprart and rattle to ****.
Get a nice quality one. And yes they will increase a little power.
Old Dec 14, 2004 | 03:58 PM
Default Re: (B30M87A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">high flow cats are a good investment, they save you a ticket and still increase power. </TD></TR></TABLE>
how do they save you a ticket?? not bein an ***.
and i got mine from shmotorsports.com
Old Dec 14, 2004 | 06:51 PM
Spade's Avatar
Default Re: (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">
and i got mine from shmotorsports.com</TD></TR></TABLE>
If you have a test pipe you get a ticket.
Old Dec 14, 2004 | 07:00 PM
NonovUrbizniz's Avatar
Loved
Also keep in mind that almost all if not all aftermarket cats are made of cheaper materials and have a tendency to go bad...
Buy from a reputable company (catco, dynomax, etc) and MAKE SURE YOU FILL OUT THE WARRANTY CARD...
My hiflo cat went bad in just under a year and I never filled out the warranty car out... so no replacement for me...
I was even warned by a mechanic I know before it went... he was like... no way it makes it more than a year... apparently stock cats are VERY expensive to produce because they use the more expensive of two optional materials (I can't remember what they're made of) where as the aftermarket ones almost always use the cheaper material that doesn't last as long.
Old Dec 14, 2004 | 08:58 PM
Spade's Avatar
Default Re: High flo Cat (NonovUrbizniz)
Stock OBDII cats go for $800 from Honda
Old Dec 14, 2004 | 09:10 PM
rafael_dias's Avatar
im gonna keep my stock cat.. hey guys i was wondering on my B16A from an EK, will the stock cat bolt on 2.5" collectors and 2.5" b-pipe? if not is there anyway i can modify it to fit? because i dont wanna lose my stock cat
Old Dec 14, 2004 | 09:59 PM
.BigSexy's Avatar
most hood white kid
does Jackson Racing make a good Hi Flow cat?? I knowJackson Racing is a reputable company, but dont know about their cats?
Old Dec 14, 2004 | 11:07 PM
snoochtodanooch's Avatar
Default Re: (egcoupe94)
honda-tech sponsor http://www.heeltoeauto.com has OBDII high flow cats.
lilvietboy
Sep 23, 2008 04:13 PM
Spazzua15
Feb 19, 2006 10:40 PM
Acutang
Nov 3, 2004 06:07 AM
95blk2draccordEXMT
Aug 7, 2003 06:38 AM
cbrf-3
May 7, 2003 07:35 PM
