Stupid emissions!!!!
Old Dec 14, 2004 | 02:20 PM
Rywire's Avatar
Default Stupid emissions!!!!
Here is the readings after my new cat.
idle
hc--267-->fail (max 100)
co--.29
co2--14.0
02--.8
nox--35
2,500rpm
hc--85
co--.85
co2--13.8
o2--.9
nox--159
What do yall think
new cat, new o2, running great, no carbon in the combustion chamber, plugs gapped at .39, timing at 16.
Ryan
Modified by droppedcrxsi at 12:57 AM 12/16/2004
Old Dec 14, 2004 | 02:44 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Stupid emissions!!!! (droppedcrxsi)
i thought you got that beast to pass the BAR? you already have to smog it again ?
Old Dec 14, 2004 | 02:46 PM
Rywire's Avatar
Default Re: Stupid emissions!!!! (b2o-vtec)
Naw, I never got it to pass emissions, the BAR passed the visual no problem, but my HC's have been high ever since I did the swap!!! Help!
Ryan
Old Dec 14, 2004 | 02:47 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
i always get it confused is HC's where they are running too hot or too cold? (rich/lean?) (do you understand waht i mean?)
Old Dec 14, 2004 | 02:50 PM
Rywire's Avatar
hc's is unburnt fuel.
Old Dec 14, 2004 | 02:57 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
damn...theres no way you can adjust that? like with an fpr or something...? i dont really know how to adjust it, so dont flame me, im just throwing out suggestions
Old Dec 14, 2004 | 02:59 PM
RCautoworks's Avatar
Your almost in the same boat as me
https://honda-tech.com/zerothread?id=1084118
Denatured alcohol seems to be a good thing, I'll let you know after I go on what I think of it.
Old Dec 14, 2004 | 04:22 PM
b18-c-rx's Avatar
Default Re: Stupid emissions!!!! (90blackcrx)
bump for ryan
id check the evap canister, make sure its not sending fuel at idle
Modified by b18-c-rx at 6:06 PM 12/14/2004
Old Dec 14, 2004 | 05:55 PM
Rywire's Avatar
Default Re: Stupid emissions!!!! (b18-c-rx)
Ok, so I have the evap green wire to the pin A20 on the p28 computer, where does the black wire go??
If i leave it how it is its right, correct? Because that wire dosent go to the ecu, so I should just leave it, and only attach the green wire to A20... Right?
Thanks yall
Old Dec 14, 2004 | 08:01 PM
Noahk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so I have the evap green wire to the pin A20 on the p28 computer, where does the black wire go??
Thanks yall
Doesn't the black just got to multi ground? I forget. But how close were you to passing? What's max at idle, 250? You're running the stock ecu program for smog, right? How many miles do you have on the car since you installed the cat? How many miles since you did the head? How old are the plugs? I assume you replaced them when you had the head off. How old is all the basic tune up stuff? Cap, rotor, plugs, ect?
I think you should run some fuel injector cleaner through, then try the water trick. Maybe there is a build up of HC's in the header and exhaust system? When was the last time you checked the compression?
Old Dec 14, 2004 | 08:18 PM
Rywire's Avatar
Default Re: Stupid emissions!!!! (Noahk)
Ya, I found the info, green wire goes to ecu, and blk is 12v power.
max at idle is 100, im 267!!!
YA, stock p72, cat has like 100 miles on it, head has like 350, didnt do the water trick because I cleaned the combustion chamber when the head was off, cap, rotor, plugs have like 4K on em, I ran injector cleaner like 4k ago, and have never done a compression test.
Thanks Noah, Ryan
ps, oil has like 400 miles on it.
Modified by droppedcrxsi at 5:36 AM 12/15/2004
Old Dec 14, 2004 | 11:32 PM
Rywire's Avatar
bump for suggestions!!
Old Dec 15, 2004 | 03:05 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
your running the p72 for when you go to smog right? (just in case you forgot ) maybe your running too rich with the p28 and then it caused a build up of HC somewhere like someone was suggesting earlier?
Old Dec 15, 2004 | 09:27 AM
Rywire's Avatar
Yes, p72... Ya Noah said I should try running water to clean the pipes, not just the combustion chamber. He also suggested to run the p72 for a while before the test.
This time I put the p72 in, ran down the freeway for about 20 min, then let it idle for 10 while the smog dude got his crap together.
Ryan
Old Dec 15, 2004 | 03:12 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
and....and...AND!!!!!!!!!!! (oh my god teh suspense is killing me did you pass?!??!??!!!??!!?!11//)
Old Dec 15, 2004 | 03:19 PM
Outsane's Avatar
what octane gas are you running?
if your not running 87 give it a shot.. that will lower your HC's
Old Dec 15, 2004 | 03:33 PM
I just passed , my hydrocarbons were still a little high but I think the cat is shot. Anyways try the denatured alcohol, you will pass for sure.
Old Dec 15, 2004 | 03:57 PM
Rywire's Avatar
Default Re: Stupid emissions!!!! (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">what octane gas are you running?
if your not running 87 give it a shot.. that will lower your HC's</TD></TR></TABLE>
Im running 91, because my compression is 10.6, wont 87 be unsafe? I dont want to ping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">I just passed , my hydrocarbons were still a little high but I think the cat is shot. Anyways try the denatured alcohol, you will pass for sure.</TD></TR></TABLE>
My HC's are 1.5 times higher than allowed, do you think this alcohol is going to make me pass?
Is it safe for the engine?
Wes V gave me a good idea, im gunna call hondata, and talk with the guru's. Possibly I can burn a chip with way less % of fuel at idle. Also, Adam had the idea for a uberdata chips as well.
Ryan
Old Dec 15, 2004 | 04:06 PM
Ryan</TD></TR></TABLE>
Original my hydrocarbons were 1.60 went today and they were .996
I replaced both o2 sensors and oil and plugs. I can say the alcohol did not hurt anything, it won't make anything worse. Also its ok for the car, just right afterwords fill you car up with gas.
Old Dec 15, 2004 | 06:17 PM
Wes V's Avatar
Ryan;
Are you sure that you don't have a cap from a tube of antiseize in one of the cylinders. I've heard that can lead to excessive hydrocarbons.
(I just had to throw that out)
Wes
Old Dec 15, 2004 | 06:18 PM
APEX CRX's Avatar
Default Re: Stupid emissions!!!! (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">Ryan;
Wes</TD></TR></TABLE>
ha ha Ryan you got PUNK'D !!
Old Dec 15, 2004 | 06:26 PM
Rywire's Avatar
WAVES FIST!!!!
HAHAHAHA
Old Dec 15, 2004 | 06:28 PM
Noahk's Avatar
Haha, you're never going to live that one down!
Old Dec 15, 2004 | 07:51 PM
APEX CRX's Avatar
Default Re: Stupid emissions!!!! (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
ha ha Ryan you got PUNK'D !!</TD></TR></TABLE>
here's a little pic just for you
[IMG][/IMG]
Old Dec 15, 2004 | 08:03 PM
bossman032's Avatar
yea one thing after another.
change the cat nox goes down but hc goes higher.
I had similar problem changed from OEM cat to Catco numbers went higher
catco is useless
try the denatured alcohol or honda data chipped for smog.
also the evap only works when engine is not on wont effect emissions
