Itr Head Gasket??
cars been boiling fluids into the resevoir, when rad cap is off it bubbles while giving it throttle, im pretty sure its the head gasket
any aftermarket headgaskets that are better then oem, think i saw something somewhere that there was a head gasket that raised compression? Or should i just stick with oem?
Whoa...can 'o worms here.
Might want to check your fluid color...oil and coolant. Also, might need to bleed the coolant.
Headgaskets...Mugen has a 2 layer that bumps compression slightly. I had it on my car for about 6 weeks before something else happened that was a bit on the catastrophic side, but not head gasket related at all.
oil's fine, coolant is fine, ive replaced
radiator
fan assembly
cts sensor
thermastat
hoses
timing belt
water pump
car dosnt go past midway line on heat guage, however it boiled fluid back into my resevoir after a 30 minute drive while getting it emission tested. Everything that can be replaced has been.......
i own a del sol but it has a 98 jdm swap
radiator
fan assembly
cts sensor
thermastat
hoses
timing belt
water pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Guilotine »</TD></TR><TR><TD CLASS="quote">HKS, TODA, Spoon, Mugen are all good aftermarket and they bump up your compression a bit
the TODA does not raise compression...
it comes in .6mm (stock), .8mm & 1.0mm (these 2 will lower your compression)
stop spreading misinformation
</TD></TR></TABLE>the TODA does not raise compression...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">
stop spreading misinformation</TD></TR></TABLE>
ok, stop crying
ok, stop crying
ok, stop crying</TD></TR></TABLE>
idiot
what is it with you ffing newbs?
a closed mouth gathers no feet
idiot
a closed mouth gathers no feet</TD></TR></TABLE>
Words to live by
Words to live by
iperez
Jan 28, 2004 03:38 PM
