Honda S2000 Honda S2000
newer s2000's get 360cc injectors stock?
Old Dec 14, 2004 | 06:19 AM
Black R's Avatar
25 Year Member
Default newer s2000's get 360cc injectors stock?
Confirm please!
Old Dec 15, 2004 | 09:29 AM
fperra's Avatar
Default Re: newer s2000's get 360cc injectors stock? (Black R)
They have always had 360 cc injectors, from the very first one made.
Old Dec 15, 2004 | 11:43 PM
autotourismo's Avatar
Well that is so.....they came std out with 360cc injectors
Old Dec 16, 2004 | 12:50 PM
fknfast's Avatar
Default Re: (autotourismo)
360
Modified by fknfast at 10:00 PM 12/17/2004
Old Dec 16, 2004 | 03:11 PM
fperra's Avatar
Default Re: (fknfast)
Wrong. They are 360 cc as tested by RC and as listed with AEM. This has been over discussed on the S2KI forum.
Old Dec 16, 2004 | 03:37 PM
CWESTINAP1's Avatar
200cc's? thats less then type r's, preludes, civics and integras.
Old Dec 17, 2004 | 07:12 AM
Black R's Avatar
25 Year Member
Default Re: (fperra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fperra &raquo;</TD></TR><TR><TD CLASS="quote">Wrong. They are 360 cc as tested by RC and as listed with AEM. This has been over discussed on the S2KI forum.</TD></TR></TABLE>
.....got a link?
The reason I'm interested is that these would be good for an allmotor buildup in a b-series... provided they'd fit.....
Old Dec 17, 2004 | 09:18 AM
cmdr430's Avatar
Default Re: (Black R)
whats up ken?
they fit....
im "rstor" i have a set for him....
Old Dec 18, 2004 | 10:24 AM
coquinn's Avatar
They will fit Ken.
Old Dec 19, 2004 | 12:09 AM
Black R's Avatar
25 Year Member
Default Re: (coquinn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquinn &raquo;</TD></TR><TR><TD CLASS="quote">They will fit Ken. </TD></TR></TABLE>
plug and play?
I've heard that the length is different or something and that the fuel rail would need to be modified to work properly..... any truth to this?
Old Dec 22, 2004 | 08:31 PM
evil vapor's Avatar
can anyone confirm if the s2k injectors are similar or same as NSX?
Old Dec 22, 2004 | 10:06 PM
Tad's Avatar
Tad
Default Re: (vapor)
so could I make these work on my dseries?
if so what would it take??
are they pintle type like most other honda injectors, or are they lucas disc like rc injectors?
Also are they saturated or not?
thanks!
Old Dec 23, 2004 | 02:30 AM
Filliam H. Muffman's Avatar
Default Re: (vapor)
so according to coquinn and vapor, NSX injectors should work in a b-series. LOL
Old Dec 23, 2004 | 08:46 AM
Black R's Avatar
25 Year Member
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">so could I make these work on my dseries?
thanks!</TD></TR></TABLE>
I'm pretty sure these are saturated and are similar to most other obd2 honda injectors in terms of the design.....
They will work on your d-series, provided you shim the fuel rail as others here have stated, however you must be running obd2.....
Old Dec 23, 2004 | 10:36 AM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
They will work on your d-series, provided you shim the fuel rail as others here have stated, however you must be running obd2..... </TD></TR></TABLE>
what kind of shimming needs to be done?
didnt see any mention of that.
but yeah, i'd run obdI, i'd just have to convert the clips right?
i'd have to do that for any other injectors I wanted anyways, like dsm's or something.
Old Feb 3, 2005 | 06:00 PM
red civic standard's Avatar
Default Re: (Tad)
I am interested in knowing how much shimming is necessary to put s2k injectors into a b series.
ongking
Nov 19, 2006 12:59 PM
88crxhfb16
Aug 23, 2005 03:51 AM
import_trung
Jun 9, 2005 02:14 PM
civicrr
Apr 24, 2004 12:09 PM
freakie
May 1, 2003 06:54 AM
