Removing a rear seat...
Old Jan 3, 2002 | 03:47 PM
Bbasso's Avatar
Default Removing a rear seat...
i have the upper section out and the lower(*** area) is stuck, I removed the 10mm bolt and its stuck feels like there are some clips or more bolts I can't see.
Here is a pic but I don't understand, whta do they mean lift and pull???
http://www.team-integra.net/ti/elec/...pk-pull-up.asp
[Modified by Bbasso, 7:49 PM 1/3/2002]
Old Jan 3, 2002 | 03:49 PM
Jason's Avatar
Default Re: Removing a rear seat... (Bbasso)
just pull, there's clips that are in the front (by where your feet would be) just pull straight up...that's the only other thing that holds them in besides the bolt
Old Jan 3, 2002 | 03:51 PM
Bbasso's Avatar
Default Re: Removing a rear seat... (typer98)
thank you, I'm off to the garage.
Old Jan 3, 2002 | 04:03 PM
B2FiNiTY's Avatar
I just took mine out last week and put it back in. Just pull once you have all the screws taken care of.
Old Jan 3, 2002 | 05:06 PM
1GreyTeg's Avatar
Any particular reason WHY you are removing it Rob?
Remember the last Auto-X we saw eachother? Well that day I was running a completely stripped interior sans the seats and center console. Needless to say it was LOUD as ****. I mean the engine noise is always a pleaser but the fuel pump whining and the road debris getting picked up and tossed around the underside of the car sounded like gravel getting sprayed on tin foil.
I guess you are either doing a stereo or alarm install? I hope one of those and not just removing the interior for kick's, Ha ha ha.
BTW for Just weight savings alone the folding upper rear seat is the heaviest, the lower portion maybe weighs 5 to 7 pounds tops and thats a high estimate, It's all foam!
Good luck, hollar if you need anything.
A.
Old Jan 3, 2002 | 10:57 PM
Bbasso's Avatar
Default Re: Removing a rear seat... (1GreyTeg)
Na I'm doing it for a radio upgrade, its been a long time since I had a nice sounding system, besides I can't hear the stock POS...
Yeah I'm not to far from getting it done. I have to make a run into Chinatown and grab some components for the front and speakers for the rear. I used to have a awsome hookup there. I hope he is still employed...
crxsleeper210
Feb 14, 2011 04:11 PM
Dave K.
Dec 18, 2005 10:13 AM
kingrd
Jul 9, 2005 02:52 PM
sunsetway
Jun 7, 2003 11:19 AM
Officer
Oct 22, 2002 06:14 PM
