96 ek hatch b18c question
Old Dec 14, 2004 | 12:07 AM
slowem1si's Avatar
Default 96 ek hatch b18c question
i have previously swaped an ls vtec into a eg and all it took was two integra mounts. Im wondering on a 96 ek hatch if you need to buy a mount kit for a b18c to bolt up or if you buy a mount kit?
also i am wondering if you want to put the 99-00 front end on it what all has to be change the headlights and front bumper, hood?
Modified by HarloRex at 1:22 AM 12/14/2004
Old Dec 14, 2004 | 06:10 AM
klungemonger's Avatar
The 99-00 body conversion is hood, lights, bumper, grille, and fenders...everything in front of the windshield basically.
Not sure about all the mounts but for sure you need the rear tranny mount from a 99-00 Si to mount a B-series into a 6g Civic. Can get them new for like $35 at http://www.slhondaparts.com
Old Dec 14, 2004 | 06:26 AM
slowem1si's Avatar
Default Re: (klungemonger)
cool
Old Dec 14, 2004 | 06:40 AM
myhatch98's Avatar
Default Re: (HarloRex)
i have an ek with a b series swap all u need is the driver side motor mount thats bolted onto the motor from a 99-00 civic si and the rear tranny mount from a 99-00 civic si and your motor will bolt right in
Old Dec 14, 2004 | 07:02 AM
blackeg's Avatar
Default Re: (myhatch98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatch98 &raquo;</TD></TR><TR><TD CLASS="quote">i have an ek with a b series swap all u need is the driver side motor mount thats bolted onto the motor from a 99-00 civic si and the rear tranny mount from a 99-00 civic si and your motor will bolt right in</TD></TR></TABLE>
i just put a b18 in my ek, those are the mounts you need.
you'll also need the b series axles, and 94+ teg or 99-00 si linkage
Old Dec 14, 2004 | 07:35 AM
slowem1si's Avatar
Default Re: (blackeg)
i knew it had to be something along those lines thanks for the help guys
Old Dec 14, 2004 | 07:43 AM
jay.dee.em1's Avatar
is this the same if im dropping in an ls? the swap im gettin comes with the stock integra mounts can i use these or do i need si mounts?
Old Dec 14, 2004 | 08:33 AM
LS and GSR is the same install process...
Old Dec 14, 2004 | 09:07 AM
blackeg's Avatar
Default Re: (jay.dee.em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay.dee.em1 &raquo;</TD></TR><TR><TD CLASS="quote">
is this the same if im dropping in an ls? the swap im gettin comes with the stock integra mounts can i use these or do i need si mounts?</TD></TR></TABLE>
you'll need the si mounts. ls is easier, because you dont have as many sensors and wires to hook up (no iab,vtec...)
Old Dec 14, 2004 | 09:51 AM
slowem1si's Avatar
gsr = more power
Old Dec 15, 2004 | 07:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HarloRex &raquo;</TD></TR><TR><TD CLASS="quote">gsr = more power</TD></TR></TABLE>
with the money i save on the LS i will have a custom turbo setup which will spank your gsr
Old Dec 15, 2004 | 10:33 AM
slowem1si's Avatar
true
ProjectBoosted
Apr 11, 2007 10:38 AM
JDM_rolex
Apr 4, 2006 08:48 AM
akteamster
Oct 21, 2005 10:17 PM
CallmeLuke
Nov 28, 2003 10:12 PM
black-hatch
Apr 21, 2003 09:08 AM
