HELP: auto tranny is locked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye »</TD></TR><TR><TD CLASS="quote">there should be a key slot or sum'n like that u , u guessed it , insert a key and press down while trying to shift out of P, should unlock
Yeah, the shift lock override SHOULD work, but do you have any idea why it locked up in the first place? Low on tranny fluid?
BTW, I seriously grow tired of you guys with nothing to add. Wouldn't happen if he had a manual? Who the **** cares. Then his ISB would go out like the rest of HT.
</TD></TR></TABLE>Yeah, the shift lock override SHOULD work, but do you have any idea why it locked up in the first place? Low on tranny fluid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye »</TD></TR><TR><TD CLASS="quote">there should be a key slot or sum'n like that u , u guessed it , insert a key and press down while trying to shift out of P, should unlock </TD></TR></TABLE>
Yeah once you get the shifter unlocked drive straight to have your tranny looked at. It's most likely not a good thing it locked up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">BTW, I seriously grow tired of you guys with nothing to add. Wouldn't happen if he had a manual? Who the **** cares. Then his ISB would go out like the rest of HT. </TD></TR></TABLE>
Damn, h-t is gettin' on your nerves tonight huh? I think you should go do something you enjoy.
well after i did my intake install the tb was was causing my tranny to lock up.. (the cable that runs to the tranny from the throttle rotor was too tight)
there is a switch solenoid in the shifter.. its controlled by the ignition and the brake pedal switch.. could be those too...
Modified by bushfreakz at 4:59 AM 12/15/2004
VTEC Sleeper
Jun 8, 2004 07:34 PM
