installed some H&R sport springs, and now.....WTF
Old Dec 13, 2004 | 07:40 PM
'00Accordster's Avatar
Default installed some H&R sport springs, and now.....WTF
My and my bud installed the front H&R sport springs on the front of my 2000 accord sedan (we ran out of time for the rear, i had to go to work ). its supposed to be a 1.5 inch but it only looks like 1/2 inch. i know the springs are supposed to settle but i figured that at least SOME of the drop would be noticable. any tips or comments?
Old Dec 13, 2004 | 08:10 PM
nizmo's Avatar
You sure you didn't switch the front and rear springs?
Old Dec 13, 2004 | 08:26 PM
Default Re: (nizmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nizmo &raquo;</TD></TR><TR><TD CLASS="quote">You sure you didn't switch the front and rear springs? </TD></TR></TABLE>
lol WTF of course not man!!
Old Dec 13, 2004 | 08:32 PM
-RedneckDave-'s Avatar
Working
Default Re: installed some H&R sport springs, and now.....WTF (95Accordster)
Let them settle. Mine has settled to about a 2" all around, and with my Yellows they it is even lower.
Old Dec 13, 2004 | 09:31 PM
sj993's Avatar
Default Re: installed some H&R sport springs, and now.....WTF (-RedneckDave-)
Yep, give it some time to settle. I did with mine and eventually they leveled out.
Old Dec 13, 2004 | 11:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- &raquo;</TD></TR><TR><TD CLASS="quote">Let them settle. Mine has settled to about a 2" all around, and with my Yellows they it is even lower.</TD></TR></TABLE>
what kind of springs you got dave?
Old Dec 13, 2004 | 11:23 PM
Default Re: installed some H&R sport springs, and now.....WTF (sj993)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, give it some time to settle. I did with mine and eventually they leveled out.</TD></TR></TABLE>
how long did it take to level out?
Old Dec 14, 2004 | 01:20 AM
nizmo's Avatar
Default Re: (95Accordster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95Accordster &raquo;</TD></TR><TR><TD CLASS="quote">lol WTF of course not man!!</TD></TR></TABLE>
Haha ok just checking.
Once you finish the rears and let them settle for awhile, you should be ok.
Old Dec 14, 2004 | 03:26 AM
SP GARAGE's Avatar
Default Re: (nizmo)
my eibach sportlines took couple days to settle. just give it some time
Old Dec 14, 2004 | 07:19 AM
yardy8301's Avatar
did you forget to cut the bumpstops?
Old Dec 14, 2004 | 09:37 AM
kevinm1981's Avatar
probably cause that back is not done yet
Old Dec 14, 2004 | 09:53 AM
Working
what kind of springs you got dave?</TD></TR></TABLE>
H&R sports
Old Dec 14, 2004 | 04:41 PM
Default Re: (yardy8301)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yardy8301 &raquo;</TD></TR><TR><TD CLASS="quote">did you forget to cut the bumpstops?</TD></TR></TABLE>
i actually i didnt cut them at all.....oh and uh BUMP
How do i cut them anyway??
Old Dec 14, 2004 | 04:46 PM
kevinm1981's Avatar
cut them in half, but the bumpstops won't lower the car any more, bump stops only come into play when you go over a bump. Lower the rear then the whole car will be way lower. Think about it if the rear is so high, it would stop the front from going down.
Old Dec 14, 2004 | 04:52 PM
Default Re: (kevinm1981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm1981 &raquo;</TD></TR><TR><TD CLASS="quote">cut them in half, but the bumpstops won't lower the car any more, bump stops only come into play when you go over a bump. Lower the rear then the whole car will be way lower. Think about it if the rear is so high, it would stop the front from going down.</TD></TR></TABLE>
makes sense. so cutting the bumpstops isnt really necessary?
Old Dec 14, 2004 | 04:57 PM
kevinm1981's Avatar
cut them, or your car will be really bouncy when you hit a bump.
Old Dec 14, 2004 | 08:32 PM
sj993's Avatar
how long did it take to level out?</TD></TR></TABLE>
2 or 3 weeks I think.
Old Dec 14, 2004 | 11:36 PM
Working
I know my car on the H&R sports with the Koni Yellows is hammered. I knock over coke cans with my undercarriage.
Old Dec 15, 2004 | 01:45 AM
Trumpster's Avatar
Man, my 1990 EX could almost knock over a 12 oz coke can with a stock setup. Either way, back to topic though, like everyone says, give some settle time and it will be fine. As far as the bumpstop thing goes, it can't hurt to cut them. I used a utility knife to cut mine and it worked out fine.
Old Dec 15, 2004 | 01:55 AM
Default Re: installed some H&R sport springs, and now.....WTF (Assassin247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Assassin247 &raquo;</TD></TR><TR><TD CLASS="quote">Man, my 1990 EX could almost knock over a 12 oz coke can with a stock setup. Either way, back to topic though, like everyone says, give some settle time and it will be fine. As far as the bumpstop thing goes, it can't hurt to cut them. I used a utility knife to cut mine and it worked out fine.</TD></TR></TABLE>
what about when i return the car to stock, would the cut bumpstops make a difference?
Old Dec 15, 2004 | 10:13 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95Accordster &raquo;</TD></TR><TR><TD CLASS="quote">what about when i return the car to stock, would the cut bumpstops make a difference?</TD></TR></TABLE>
Yes and stop asking the same question 2000 times, eibach's lowering spring comes with a guide for how much bumpstop to cut
Old Dec 15, 2004 | 04:42 PM
Default Re: installed some H&R sport springs, and now.....WTF (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
Yes and stop asking the same question 2000 times, eibach's lowering spring comes with a guide for how much bumpstop to cut</TD></TR></TABLE>
That would actually help if i had eibach's, and im not asking the same question 2000 times, if you were actually reading you would have seen that
Old Dec 15, 2004 | 04:43 PM
so again, when the car is returned to stock how would the cut bumpstops affect the STOCK ride
Old Dec 15, 2004 | 05:29 PM
95allmotor's Avatar
When its back to stock it will not affect it to a point anyone would notice. Inless they duke of style drove the car over speedbumps . You will be fine, enjoy the lowered look and ride.
Old Dec 15, 2004 | 06:22 PM
Default Re: installed some H&R sport springs, and now.....WTF (95allmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95allmotor &raquo;</TD></TR><TR><TD CLASS="quote">When its back to stock it will not affect it to a point anyone would notice. Inless they duke of style drove the car over speedbumps . You will be fine, enjoy the lowered look and ride.</TD></TR></TABLE>
Thank you sir, and all of you for your help and advice!!!!!!
