1993 Accord Helms Manual HELP please! sway bar install....
Old Jan 3, 2002 | 02:14 PM
briq4's Avatar
Default 1993 Accord Helms Manual HELP please! sway bar install....
If anyone has a helms manual and can find the torque specification for the bolts (17mm) that hold the sub frame (the rear suspension mounts to this frame) to the body I would greatly appreciate it. Seems the crappy Chilton Manual I have does not list this. There are 4 bolts total under the car and I am removing the center two to mount a new sway bar, but now I'm lost due to not knowing what the torque should be. Any help would be GREATLY appreciated.
Thanks in advance!
Brian
Old Jan 3, 2002 | 02:24 PM
smokin rubber's Avatar
Default Re: 1993 Accord Helms Manual HELP please! sway bar install.... (briq4)
The haynes lists
"trailing arm bracket-to-body bolts 47Ft-lbs"
I think this is what you are loking for
have fun with those new sway bars
[Modified by smokin rubber, 6:25 PM 1/3/2002]
Old Jan 3, 2002 | 02:26 PM
briq4's Avatar
Default Re: 1993 Accord Helms Manual HELP please! sway bar install.... (smokin rubber)
Smokin Rubber you are DA MAN. thanks. I called my local honda dealer and they are of course too busy to check and I can't driver there (due to the car being in some pieces. But thanks VERY much. THey seemed really loose when I took them off, so that makes sense. Thanks again.
Old Jan 3, 2002 | 02:37 PM
no problem
Nice Room
Aug 25, 2014 05:54 AM
eurocrx
Sep 3, 2010 03:55 PM
Andrew 825SM
Jan 19, 2004 12:03 PM
tokyoracer
Aug 9, 2003 04:08 AM
