How is idle when using aftermarket cams on a street car?
Just wondering how most people make out with aftermaket cams on daily driven cars? I have Skunk II Stage II cams where i need to keep on the gas for aboout a minute before i start driving around. Is that faily normal for aftermarket cams, or should i do more tuning?
Do other brands have the same affect. I read a lot about dyno's and performance numbers, but how do stack up on your daily driver?
The Skunk 2's should idle like stock. Mine did. Toda cams are a bit more finicky, but can be made to idle well.
skunk2 stage 2 should idle like stock.
when i first put them in it was very hard to idle. setting the timing back to stock helped alot.
after tuning they idle great alittle lopy but idles like stock in terms of smoothness
i want to know this info also....looking into buying cams soon for a daily driver....anyone else got info on which cams are easy to tune?....are the s2s2 easy to tune?....how bout buddy club III+/IVs?
on my car if i advance the intake +2. it would stall out ocassionally. its best to leave it at 0 and take it to the dyno to see.
on my motor i made the most power out of them at 0 setting.
tuning is the key to making them idle nice
your probably just running real rich at idle. if you have a vafc, it would just lean it out til the idle stops fluctuating at normal operation temperature and adjust the throttle body screw to idle at about 750 rpms. that could be the case like usual.
i have Toda Bs and purrs like a kitten.
How about the crower 403's or 404 LS cams? I know the 403's will idle near stock but just curious on how the idle will be on the 404's. I want the most out of my b20b but dont want sacrafice the healthy idle. Please dont flame me for sporting a non-vtec b-series.
When i had my fully built all motor ls/vtec with my crower 403 cams and tuned hondata the car idled perfectly
Most people didnt even know that I had cams cause the idle was so good
Teamdiesel
Jan 16, 2006 07:35 PM
sleepystyle
Oct 1, 2005 05:09 PM
Calavera
Mar 29, 2003 12:31 PM
