installing front door speakers
Old Dec 13, 2004 | 02:35 PM
SPARTUS's Avatar
From: Highest crime rate in the nation, per square mile, MD
Default installing front door speakers
hey all,
I want to install new front door speakers in a 1998 honda civic hx coupe. in order to install new speakers, do i need to take apart the whole door or can i just remove the front speaker grills. can anyone point me into the right direction with a link perhaps?
thanks
Old Dec 13, 2004 | 02:38 PM
A.E Motoring's Avatar
Default Re: installing front door speakers (SPARTUS)
you should be able just take the speaker grills off...and then take the speaker out
Old Dec 19, 2004 | 04:51 AM
s2000june's Avatar
covers pop right off and its like 3 or 4 screws holding the speaker in.
do you know what size the front door speakers are. i need some new ones for my 00.
Old Dec 19, 2004 | 05:46 AM
ocdcivic's Avatar
Default Re: (civicrida3)
i believe they are 6 1/2 in the fronts.... and 6x9 in the rear
Old Dec 19, 2004 | 06:06 AM
jlacoy82's Avatar
71.192.16.183
Default Re: (ocdcivic)
I put aftermarket 6.5"s in my front doors, and they were WAAAAAAY bigger in diameter than "6.5s" that Honda had in there, they were also about 3" deep. After cutting away most of the pocket behind the speaker grill, and making the hole in the sheet metal about 3/4" in diameter larger, and making a speaker ring to mount to the door to space the speaker out, they dropped right in. And the xovers fit nicely in the big plastic pocket in the moisture barrier just beneath where the manual door lock buttons are. I mounted mine with some 1/8" x 1" aluminum strips bolted to the door.
Basically........if you want to just "drop in" speakers, make absolutely sure you get the correct size and depth, or have a shop do it, but like me, I already had a nice set of 6.5" components I had used in cars previously, and I did what it took to get them in. I also had to run new 12g through the factory boot into the door for the power.
Old Dec 19, 2004 | 02:46 PM
SPARTUS's Avatar
Default Re: (jlacoy82)
thanks for the replies. my friend is putting in Dual XP65i speakers. they are 6.5 inches. can someone check the specs and see if they fit right in?
Old Dec 19, 2004 | 02:47 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (SPARTUS)
My 92 hatch has 5.25 inch speakers in the front. I don't know if all civics held the same size throughout the years though.
Old Dec 20, 2004 | 03:46 AM
ocdcivic's Avatar
Default Re: (litterbox)
like mentioned before 6.5's will fit in the front door panel you might just have to do minor modification to get it to fit...(depth, screws) i have a set of 6.5's and they fit fine. Any audio place will tell you the same thing to install 6.5's.
Grade50
Audio / Security / Video
Apr 23, 2014 05:58 PM
kornerk12
Nov 3, 2008 04:34 AM
journeyquest
Oct 27, 2008 04:45 AM
SCIVIC94
Mar 20, 2007 10:24 PM
Thrillhouse
Jun 25, 2002 02:35 PM
