External Coil to Internal Coil !!!HELP!!!
Old Dec 13, 2004 | 01:58 PM
Stoich EG2's Avatar
Default External Coil to Internal Coil !!!HELP!!!
So I'm in the process of swapping engines. my old harness has 8 wires going to the EXTERNAL COIL Distributor. My new JDM engine has 7 wires coming out of it... how do I make this work?!?! it's a JDM H22A BTW... OBD1... I found that the extra wire from the wiring harness is a solid green one. If i just plug it in without the green plug, will this work? thanks. i asked the Tech section and no one knew either... and i know EG civic guys know alot
I hope this helps. you picture ******
Old Dec 13, 2004 | 02:53 PM
RedlinedVTEC's Avatar
Default Re: External Coil to Internal Coil !!!HELP!!! (Advan06)
Here's a helpful reply for you:
Helpful reply.
Old Dec 13, 2004 | 08:09 PM
Stoich EG2's Avatar
Default Re: External Coil to Internal Coil !!!HELP!!! (RedlinedVTEC)
no one?
Old Dec 13, 2004 | 08:14 PM
94_HATCH's Avatar
i belive that there is an external to internal coil dizzy write dont by hondaZvic. search under his name and you should find it.
Old Dec 13, 2004 | 09:16 PM
Stoich EG2's Avatar
Default Re: External Coil to Internal Coil !!!HELP!!! (94_HATCH)
didnt find it...
Old Dec 13, 2004 | 10:41 PM
Stoich EG2's Avatar
Internal/External Coil Issues
If your car came equiped with an internal coil then the jdm h22 distributor will plug right in no problem. However, if your car had external coil then you will have to modify one plug. The plug you will need to modify is the plug that went to the stock coil. There are is a yellow and a yellow/black wire, splice those 2 wire together. The green wire is useless, dont worry about it.
OK, is this what the man is talking about?...
Stoich EG2's Avatar
and also...
Old Dec 14, 2004 | 01:39 AM
Stoich EG2's Avatar
bloop anyone? i know someone out there is a wiring guru
Old Dec 14, 2004 | 06:28 PM
Stoich EG2's Avatar
anyone else?
Old Dec 14, 2004 | 06:38 PM
slow94coupe's Avatar
good luck and you should learn how to solder its alot cleaner than those crimp things.
Old Dec 14, 2004 | 07:19 PM
Stoich EG2's Avatar
Default Re: External Coil to Internal Coil !!!HELP!!! (slow94coupe)
thanks for the advice...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow94coupe &raquo;</TD></TR><TR><TD CLASS="quote">good luck and you should learn how to solder its alot cleaner than those crimp things.</TD></TR></TABLE>
i'd rather have the question answered though
Old Dec 14, 2004 | 07:22 PM
Archidictus's Avatar
Unceasing Measure
[Tenacious D]Take the green wire and put it in your ***![/Tenacious D].
Old Dec 14, 2004 | 07:37 PM
Stoich EG2's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">[Tenacious D]Take the green wire and put it in your ***![/Tenacious D].</TD></TR></TABLE>
i dont think that's where it goes. thanks though
Old Dec 15, 2004 | 09:34 AM
2fast4u831's Avatar
I'm really 2slow
I dont think you need to mess with it if its in your car harness since your h22 only has 7. That one will just sit right there and watch
Old Jan 12, 2005 | 07:17 PM
azzinine1's Avatar
Default Re: (2FAST4U831)
I have been searching for this info for a couple hours along with some other stuff and i have two wires left out of 20 i sat down to figure out. There is a light green wire that was in a clip that connected to the distributor the clip had 4 wires Black, Yellow/Green, Yellow, and Lime (light green) i figured out all but the Lime one and there is a yellow wire that was in a clip with a blue wire that conected to the ecu does anyone know where these 2 wires go???
tichal2008
Nov 10, 2009 09:20 PM
oneprelude
Dec 7, 2008 02:14 AM
turboh22civic
May 24, 2007 03:48 PM
cb9sir
Oct 20, 2004 07:34 AM
type-t
Aug 19, 2004 06:40 PM
