Location of TDC Sensor
On the way home from work tonight, the infamous CEL popped on. I checked it, and think it's a code 8, I just get 8 long flashes. Checked the list, and it's TDC sensor. Car is a 99 DX hatch with the D16Y7.
1. Is this sensor in the distributor and are there any common problems associated with it?
2. I just replaced the timing belt maybe 1000 miles ago. No problems whatsoever. Car still runs just fine even after the code is up. I know the crank fluctuation sensor is down at the bottom, so it's not that one. But is it associated with the belt at all?
Is this a replace dizzy thing or just reset and see if it comes back? I'll check the timing and make sure everything is plugged into the dizzy correctly. Thanks.
BTW: Searching revealed mixed views and problems. Very few were related to Civic's also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbscivichb92 »</TD></TR><TR><TD CLASS="quote">reset the ecu and if it still comes back you can get a distributer housing assembly for about $100. they don't just sell the tdc sensor.</TD></TR></TABLE>
Correct, your TDC is part of your dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Isn't it:
Short flashes = 1
Long flashes = 10
Where 8 long flashes will = 80?</TD></TR></TABLE>
charo0
Short flashes = 1
Long flashes = 10
charo0
Short flashes = 1
Long flashes = 10
See I originally thought this too, however there isn't a code 80 on the list of ECU codes, not to say that maybe it doesn't exist. But I thought the same might be true.
Can anyone confirm this, or possibly shed some light as to what code 80 might be? The CEL came on as soon as I started the car, I didn't even pull out of the parking spot. And it wasn't on this morning.
I've reset the light and thus far it hasn't come back on after driving approx. 20 minutes :crosses fingers:
Short flashes = 1
Long flashes = 10
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">however there isn't a code 80 on the list of ECU codes, not to say that maybe it doesn't exist. </TD></TR></TABLE>
This is why I prefer P codes.....they always exist somewhere in the Helms manuals!
krisfnbs
Honda Civic (2001 - 2005)
30
Jul 5, 2024 03:30 PM
90RENOsedan
Dec 21, 2009 10:14 PM
