prelude fuse panel
hey, guys, just need some info on the 4th gen fuse panel- mostly, which one is the fuel pump fuse- and yes, i've searched and no, i don't have the cover with the diagram on it
any info would be greatly appriciated
thanx, -- Cory
thanx, -- Cory
i looked briefly (yes briefly) thru the helms - and don't see a fuse for it - it's not one of the fuses in the under hood fusebox anyways...
the fuel pump is switched on thru the pgm-fi notably pins 5 (ign) to 7 (fuel pump).
if i were you i would just go to the source - lift the access panel in the trunk and remove the 2 pin connector. that will basically unplug the fuel pump and you should be set. I would also relieve the fuel pressure via the service bolt on the fuel rail.
my advice is based on a 4th gen - not sure what you have though.
good luck - too bad about the hydrolock - hope everything is a-ok.
I don't think honda have a fuse for fuel pump... they are control by the ECM and sometime use the PGM-FI fuse. This fuse will disable all fuel, spark, and cam input to the ECM. It should be a 7.5amp and the #3 on the lower roll. Because the #1 is a spare and #2 is not used...
