ATTN: EK/EJ hatchback with B-swap owners...exhaust question!
Old Dec 13, 2004 | 11:48 AM
kinvid22's Avatar
Default ATTN: EK/EJ hatchback with B-swap owners...exhaust question!
So i got a B20 on my 98 hatch. I want to run straight piping for awhile. If i pick up a 96-00 Civic hatch Apexi cat-back exhaust, it should bolt right up to my type r dc header without the cat right?
Will the bolt holes on the flanges on type r header and dx hatch exhaust piping match up? Will the bolt holes line up together?
tia
Old Dec 13, 2004 | 11:52 AM
klungemonger's Avatar
Well, you'll have to get an exhaust for the 96-00 hatch, otherwise the axleback section won't fit. I put a B16 with ITR header in my friend's 98 hatch with a Tanabe exhuast. The flanges are in the right location but the ITR is waaay bigger. You'll have to have the flange hacked off the B-pipe and a bigger one put on. I suggest using a reducer so the flow necks down smoother.
Old Dec 13, 2004 | 12:27 PM
kinvid22's Avatar
Default Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">Well, you'll have to get an exhaust for the 96-00 hatch, otherwise the axleback section won't fit. I put a B16 with ITR header in my friend's 98 hatch with a Tanabe exhuast. The flanges are in the right location but the ITR is waaay bigger. You'll have to have the flange hacked off the B-pipe and a bigger one put on. I suggest using a reducer so the flow necks down smoother.</TD></TR></TABLE>
I'm getting an apexi catback for the dx hatch application. I have the usdm dc type r header so the flange is about the same size...my question is did the bolt holes line up together..i know on the header is tilted...
Old Dec 13, 2004 | 09:55 PM
kinvid22's Avatar
Default Re: ATTN: EK/EJ hatchback with B-swap owners...exhaust question! (kinvid)
bump
ProBlackHawk
Sep 4, 2012 03:51 PM
aboos
Sep 12, 2007 02:50 PM
Deano_D aka "Brick Top"
May 20, 2006 03:48 AM
kinvid22
Dec 13, 2004 12:18 PM
Nameless RB26
Sep 6, 2002 03:15 PM
