15 inch VS 16 inch
Old Dec 13, 2004 | 11:34 AM
ELAMINT5's Avatar
Default 15 inch VS 16 inch
Arlight guys I need help with rim choice. I am curently running my 17 inch VOLK TE37 on my CRX and I am tired of the TONKA TRUCK look. I am going to get the RED GT3 but can not decide between 15 and 16 inch rims.
Is there a benifit for going 15 vs 16? I have Skunk2 Coilvers, Totiko Lumina Shocks, and a camber kit installed so RUBBING IS A HUGH ISSUE(another reason for putting the VOLKS back in the garage).
My thought was to go 15 inch but while researching on here I seen that many people say to use a 195/55/15 on a 15 inch wheel. I just think that tire is to narrow. Help me end this headache.
Old Dec 13, 2004 | 11:45 AM
BlueShadow's Avatar
Default Re: 15 inch VS 16 inch (ELAMINT5)
15" larger selection of tire manufacturers to chose from
16" can run larger brakes
Old Dec 13, 2004 | 12:12 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: 15 inch VS 16 inch (BlueShadow)
I like 15s looks wise lighter tons of good tires
16s........
You really dont need a bigger brake kit imo so that doesn't matter
Old Dec 13, 2004 | 12:20 PM
HT Chaplain's Avatar
Loved
Default Re: 15 inch VS 16 inch (Ace$nyper)
15's you can get 11 inch brakes under there and that plenty of stopping power.
Modified by HT Chaplin at 3:31 PM 12/13/2004
Old Dec 13, 2004 | 01:19 PM
kim_2_da_chee's Avatar
Default Re: 15 inch VS 16 inch (HT Chaplin)
195 55 R15 is DEFINATELY not narrow. Come on, it's not a 500HP viper... 195 is more than sufficient for our civics IMO.
16" does look nice. But like the guy above said, you can fit bigger rotors with 15" wheels as well.
If you really think 195 is too narrow for a tire, there are 205 sizes that fit 15" wheels, it just depends how wide your rim is.
Old Dec 13, 2004 | 01:20 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELAMINT5 &raquo;</TD></TR><TR><TD CLASS="quote">My thought was to go 15 inch but while researching on here I seen that many people say to use a 195/55/15 on a 15 inch wheel. I just think that tire is to narrow. Help me end this headache.</TD></TR></TABLE>
Try 205's if 195's are too narrow. I run 205/50/15 with DA brakes on all corners.
IMO 15's are perfect for my little ED6.
Old Dec 13, 2004 | 01:29 PM
ELAMINT5's Avatar
Default Re: 15 inch VS 16 inch (kim_2_da_chee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">195 55 R15 is DEFINATELY not narrow. Come on, it's not a 500HP viper... 195 is more than sufficient for our civics IMO.
If you really think 195 is too narrow for a tire, there are 205 sizes that fit 15" wheels, it just depends how wide your rim is.</TD></TR></TABLE>
well actually I am going to be trying to put down in 400's with Full-Race stage 3 kit. Hopefully in the high 400's...granted who knows how much I am going to really produce when it gets installed.
Anyway, I think I am going to get the 205/50/15, for some reason 195 just scares me.
Old Dec 13, 2004 | 01:30 PM
drdisco69's Avatar
Default Re: 15 inch VS 16 inch (eda6)
15s are teh win.
Old Dec 13, 2004 | 01:31 PM
88 rex's Avatar
Good luck with 15's and ALL THAT POWER! All spin and no traction.
Old Dec 13, 2004 | 02:03 PM
ELAMINT5's Avatar
Default Re: 15 inch VS 16 inch (88 rex)
that is what I am afraid of. If they don't work I will have another dope set lying around to put on my next car.
Old Dec 13, 2004 | 02:16 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">Good luck with 15's and ALL THAT POWER! All spin and no traction.</TD></TR></TABLE>
Bah, if you have some good tires and lsd, you can run 13's all day....provided you have the power to do so.
Old Dec 13, 2004 | 02:35 PM
ELAMINT5's Avatar
Default Re: 15 inch VS 16 inch (Deetz)
if I get their stage 3 kit and the best I run 13's I will burn the ******. and that is a promise and a threat to my crx.
what are some good 15 inch tires? I was going to get Falken 451 but they do not make 15's. And I will not buy YOKO, unless they are ADVAN's. I have totalled 2 cars on those damn things.
I have had good luck with Falken and do not know which tires to get since they dont make 451. Are the Azenis good? Has anyone used them. I am down for opinons so I can research. Thanks for the input!
Old Dec 13, 2004 | 02:40 PM
ELAMINT5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">I like 15s looks wise lighter tons of good tires
16s........
While trying to find tires I have found that there are many other choices in 16 not 15.
Old Dec 13, 2004 | 02:41 PM
Deetz's Avatar
Crazy Honda Guy
What is it you'll burn?
I use Toyo T1S tires, awesome for the street/strip. 195/50/15
Old Dec 13, 2004 | 02:50 PM
wreckedrex's Avatar
Default Re: (Deetz)
People seem to like the Azenis. I haven't owned a set myself, but my brother's got a set on his miata and they feel fantastic. I'd say 195-50-15 whatever would be fine for the street, and get a separate set of 13's with slicks for the strip. It seems to me that the power you plan on putting down would make a set of slicks worthwhile. Besides, you shouldn't be worried about being able to put that kind of power down on the street
Dan
Old Dec 13, 2004 | 03:07 PM
xci_ed6's Avatar
Default Re: (wreckedrex)
205/50/15 is only off stock by 1.5% and has a pretty good (maybe better) selection.
Old Dec 13, 2004 | 04:54 PM
Recluse03's Avatar
Default Re: (krustindumm)
yeah 205/50/15 is actually proabbly going to be more widely available. i myself run 195s with no problem, how ever i am not runniogn that much power at all. azenis are good for street, and decent for strip, considering what they are, but i'd say also go with some 13's and slicks if you really want to get decent traction.
Old Dec 13, 2004 | 04:58 PM
SETI20's Avatar
I hate the sidewall roll on my toyo proxes T1-S. Even at high Psi.
I like 16" better provided it doesn't give me a weight disadvantage.
Old Dec 13, 2004 | 05:11 PM
drdisco69's Avatar
Default Re: (Recluse03)
Azenis are kinda shitty for drag racing, as the sidewall is too stiff. They are great for the "real" track.
Old Dec 14, 2004 | 08:07 AM
ELAMINT5's Avatar
Default Re: (drdisco69)
well damn. it looks like I am going to go with the yoko es100. I pray I have better luck on these tires than my last 2 cars. I know that I am not going to get much power down while I am using my GT3, so slicks are second on my have to get list. First is Gearspeed tranny rebuild with LSD. Thanks for everyones input and help trying to end this headache.
Senbonzakura
Nov 5, 2006 01:31 PM
pythoner
Oct 5, 2006 08:01 AM
Dreamworx
Jun 13, 2004 08:00 AM
AllMotorITR
May 20, 2002 09:46 PM
