Ground control coilovers with agx struts and srr lca problems
Old Dec 13, 2004 | 11:31 AM
hybridtuner23's Avatar
Default Ground control coilovers with agx struts and srr lca problems
I recently installed ground control coilovers and agx struts all around along with ssr rear control arms and new bolts in the back. When i did this swap i started out with lowering springs and stock struts which blew out not soon after i lowered the car , but when i went in to do this swap i noticed all the things in the back that have bushings were all shot , the arm that bolt to the frame that affects camber was totally ripped and i could turn the metal inside part with ease, its not longer connected, and also the part that run towards the front of the car has a busging that looks like an engine mount that seems ripped up to? Is this from lowering wihth bad struts or are these normal wear ? Can these bushings be reaplced or do i need the whole metal parts and all? Also since i did this swap i noticed the car still feels very rough when i hit bumps with the agx's om setting 1 and the cars tends to bouce alot on the highway. I had a 4 door ef with agx's and stock springs and it road smoother than any other honda i ever road in so i figured thats how this would be but its not , and i dont even have the car lowered , i have it at stock ride height until i get some camber kits and new tires. One other point i wanted to ask about was does anyone else have this setup with the srr control arms , mine come dangerously close if not actually contacting the rear strut mounting point , i dont want these things getting gashed up or maybe they just have very little clearance. Well anyways i hope someone can give me some advice , sorry about the long post.
Old Dec 13, 2004 | 10:47 PM
Default Re: Ground control coilovers with agx struts and srr lca problems (hybridtuner23)
bump..
Old Dec 13, 2004 | 11:32 PM
slammed_93_hatch's Avatar
**** paragraphs and knowing the names of parts is help full,
i had the same combo a while back its not the setup falt mine was fine
93delboosted
Nov 17, 2014 07:07 PM
polyhonda
Suspension & Brakes
Oct 14, 2007 05:26 PM
all-mtr-teg
Suspension & Brakes
Mar 5, 2007 02:42 PM
ScottEK
Sep 13, 2002 06:27 AM
se93
Mar 30, 2002 11:44 PM
