what to do when over tqed valve cover bolts
Old Dec 13, 2004 | 03:01 AM
yeegsr's Avatar
Default what to do when over tqed valve cover bolts
about 3months ago...i noticed my valve's bolts (the two next to distributor) were over tq's and nothing happened back then.....recently, 3 week...i decided to do some clean up work for my engine bay...i saw at one of the two bolts, there are oil surrounds...so i clean it up and two weeks later...i popped up the hood...and i saw oil again...
could it be the oil leak up thro the thread (over tq'ed) of the botl due the high pressure inside the valve? im sure it not from valve's gasket so...
give me some advices plz..thanx
Old Dec 13, 2004 | 05:25 AM
JimBlake's Avatar
Default Re: what to do when over tqed valve cover bolts (yeegsr)
If your PCV system is working right, there isn't high pressure in the valve cover.
Probably what you need is new rubber grommets for underneath the valve cover nuts. They get hard with heat & age, then they don't seal. (Just like the VC gasket itself.)
Old Dec 13, 2004 | 05:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Overtorqued, you mean like broken? When I bought my car one of the valve cover studs that the spark plug cover goes onto (the inner four) was broken and could spin freely. Since it wasn't pressing down on the stud grommet, oil could come out and it made an oil stain around it on my valve cover. You'll need to remove the valve cover and replace the stud, pretty easy job.
Old Dec 13, 2004 | 07:32 AM
sleevedgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Overtorqued, you mean like broken? When I bought my car one of the valve cover studs that the spark plug cover goes onto (the inner four) was broken and could spin freely. Since it wasn't pressing down on the stud grommet, oil could come out and it made an oil stain around it on my valve cover. You'll need to remove the valve cover and replace the stud, pretty easy job.</TD></TR></TABLE>
Precisely
Menaco777
May 7, 2018 06:27 PM
prodjay10
Honda Civic (2001 - 2005)
Dec 12, 2015 09:29 PM
civic=goodgasmileage
May 25, 2010 01:31 PM
optikal_blitz
Apr 21, 2003 01:44 PM
schwett
Nov 24, 2001 07:37 AM
