high compression poor mans type r?
I'm building a poor mans typer with this setup
b18c1 block
p30 pistons
pr3 head
est comp 11.7:1
I'm wondering what i need to do fuel wise? Is there an alternative to hondata or uberdata for a safe setup, or will i even need anything? I have a walbro 255 fuel pump right now.
Modified by gSIr at 9:54 PM 12/12/2004
b18c1 block
p30 pistons
pr3 head
est comp 11.7:1
Thats basically my same setup thats in the works right now. I plan to convert to OBD1 and use some sort of datalogging hopefully. Bump for more info.
obd1 for sure :-)
You could run a base skunk2 style program on stock injectors with your WOT fuel pressure set around 52 psi. This will be fine until you can dyno tune the setup.
I'm planning on converting to obd1 to run uberdata in the future, but since i'm buildin the motor now, money is kind of an issue. I'm trying to figure out what I can do for fuel until then. Can I use just my vafc or do I have to get a fuel pressure reg too?
frostcivic
Jun 17, 2004 06:18 PM
