ITR header question
Ight i have great issues with searches i cna never come up with what im looking for, so if its there already i dont want to here a lot of fussin, I have a '94 gsr and just need to know if a type-r header will just bolt on to the stock cat or if i need to change rest of my exhaust as well.
the usdm type r header will bolt up to your head and fit your stock cat, but modification may be needed since the length of the a-pipe (the lower portion of the header) is slightly different on type r's than on 94-99 gsr's.
yes it will bolt rite on, but remember that jdm itr collector is 2.5 while the usdm cat inlet is 2.38 and the hole where u put bolts wont line up... so just get a aftermarket or jdm itr cat too..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock_LS »</TD></TR><TR><TD CLASS="quote">yes it will bolt rite on, but remember that jdm itr collector is 2.5 while the usdm cat inlet is 2.38</TD></TR></TABLE>the usdm type r header has a 2" collector, so an aftermarket cat isn't needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy »</TD></TR><TR><TD CLASS="quote">the usdm type r header has a 2" collector, so an aftermarket cat isn't needed.</TD></TR></TABLE>
oh yeah mah bad.. i was talkin about the piping of usdm itr...
btw he didnt specify too if its jdm itr or usdm itr headers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock_LS »</TD></TR><TR><TD CLASS="quote">oh yeah mah bad.. i was talkin about the piping of usdm itr...
btw he didnt specify too if its jdm itr or usdm itr headers </TD></TR></TABLE>
USDM ITR exhaust piping is not 2.36 (60mm), if my memory serves it is closer to 2.25 with a couple of 2 inch bottlenecks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) »</TD></TR><TR><TD CLASS="quote">
USDM ITR exhaust piping is not 2.36 (60mm), if my memory serves it is closer to 2.25 with a couple of 2 inch bottlenecks.</TD></TR></TABLE>memory serves correctly, that is correct
