Ignition Timing Range
What is the stock ignition timing range of the distributor on a D16A6 (What would you be reading if your distributor was at full advance and full retard) when everything is else is set to stock values (cam to crank timing)?
Well, we can always come to our own conclusion. I am at 10 degrees at full advance, but that is what is takening to line up all the lines which has led me to the conclusion that my timing belt is off a tooth. Hence forth my earlier thread - https://honda-tech.com/zerothread?id=1073810
Well, I'm pretty sure my timing belt is not off and I can't get much past about 26* at 3K RPM. I'm trying to get to 34-36* advanced. Here is how I checked my timing belt...
Line up the TDC notch with the little view window:
Then check that the mark on the cam pulley lines up with the plastic arrow in the belt cover:
dr_latino999
Dec 2, 2004 09:55 PM
