Eibach Springs??
Old Dec 12, 2004 | 06:43 PM
Style'n'Sound's Avatar
Default Eibach Springs??
Any good remarks about Eibach Springs? If so, what kit and size. If not, what would you recomend. . . . ?
Old Dec 12, 2004 | 07:25 PM
FatJoe's Avatar
Default Re: Eibach Springs?? (Style'n'Sound)
i had eibach sportlines on my 90 accord 4dr....absolutely perfect for what i was lookin for...which was a comfortable ride that gave me great handling whenever i wanted it. i would recommend something a lil stiffer for the autoX'er tho.
Old Dec 12, 2004 | 07:42 PM
Shinbo's Avatar
Default Re: Eibach Springs?? (FatJoe)
sportlines will require you to swap out your stock shocks with aftermarket ones, while the prokit wont. sportlines will give you a greater drop than the prokit. the difference in ride... i can't say since i have never ridden a car with sportlines before, but i have heard good things about them. FatJoe also has a good testimony about sportlines as well.
Old Dec 12, 2004 | 09:33 PM
Broken Gearbox's Avatar
My friend had sportlines on his Del Sol with stock shocks and i was suprised how the ride was. It wasnt that bouncy at all.
Old Dec 13, 2004 | 03:35 AM
porter843's Avatar
Default Re: (2.2L)
I just put Eibach Sportlines on my '92 2-Door. I also installed KYB AGX and Camber Adjustment kit on all four. The ride is just a little bit stiffer than stock and that is a good thing. The car rides well. Just don't put 215/45R17 tires on it. It is too low to do anything with. I would go with the Proline springs in hindsight. And you should be able to use stock dampers with the prolines although I would not recommend it. You won't need a camber adjustment kit for the prolines either, supposedly!
Old Dec 13, 2004 | 05:09 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (porter843)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porter843 &raquo;</TD></TR><TR><TD CLASS="quote">I just put Eibach Sportlines on my '92 2-Door. I also installed KYB AGX and Camber Adjustment kit on all four. The ride is just a little bit stiffer than stock and that is a good thing. The car rides well. Just don't put 215/45R17 tires on it. It is too low to do anything with. I would go with the Proline springs in hindsight. And you should be able to use stock dampers with the prolines although I would not recommend it. You won't need a camber adjustment kit for the prolines either, supposedly!</TD></TR></TABLE>
I think you meant Pro-Kit and not proline.
to the OP:
I had Pro-Kit springs with Tokico struts on my 95 EX. I liked the ride, handled well for a daily driver. Would go with something stiffer if you autox. From what people have said, the main difference between the sportlines and Pro-Kits is the drop. The pro-kit has progressive spring rates and I'm told the sportlines do as well. So if you want Eibach and want more of a drop, then get the sportlines. If you want Eibach and want a mild drop, then get the Pro-Kit.
In all honesty though. This has been covered a lot and you should have tried searching before asking this question. You would have found a lot of personal experiences from people using Eibach spings.
dgdarien
Suspension & Brakes
24
Nov 25, 2015 04:22 PM
rotothedoubles
Nov 25, 2007 10:44 AM
eh6
Oct 10, 2004 04:22 PM
Chubakon
Sep 7, 2004 08:18 PM
jordan88
22
Mar 10, 2003 01:47 PM
