put springs in my car (has link) Bumpstop ?
Old Dec 12, 2004 | 06:10 PM
whiteDCfiver's Avatar
Default front bump stop question in DC5
So i lowered my car with Tein S techs. You can see it here https://honda-tech.com/zerothread?id=1083262 I had a question about the bump stops in the front. I've heard that you are supposed to cut them. However, the front stops are this enclosure that fits over the strut. If i cut it, the protective part will not stay and be useless.
Am i supposed to cut them? Leave it? Or get certain aftermarket ones?
The reason i ask is because on bigger bumps, especially on the freeway, i can feel the car bottom out. Its not bad, but you can still feel it if the car drops low enough.
Modified by whiteDCfiver at 9:02 AM 12/15/2004
Old Dec 14, 2004 | 02:39 PM
Default Re: put springs in my car (has link) Bumpstop ? (whiteDCfiver)
Anyone please. I did a search with no luck.
Old Dec 15, 2004 | 04:05 PM
jspec rsx's Avatar
you were suppose to cut them
Old Dec 15, 2004 | 05:36 PM
Hkysk8r07
Guest
Posts: n/a
Default Re: front bump stop question in DC5 (whiteDCfiver)
eibach has the info on cutting bump stops correctly. you gotta cut a certain amount from the top and bottom of the bump stop. it's different for different cars. i dont have to do it for my car. but try and find the info for the pro-kit or sportlines whichever is closest to the tien S in drop.
Old Dec 16, 2004 | 07:13 PM
MooFX's Avatar
Default Re: front bump stop question in DC5 (Hkysk8r07)
There should be instructions with the box telling you how much to cut.. It did with the eibach springs anyways.
Justin @ AJR
Old Dec 17, 2004 | 09:56 AM
Default Re: front bump stop question in DC5 (MooFX)
Ya teins instructions weren't too good. The reason im asking about this is because the front bump stop is like boot that fits over the top of the strut. ANyone who has done it knows what it is. If i cut it though, atleast the way im lookin at it, the protective boot wont stay over the shaft of the strut. Wasnt sure if that was normal or not.
Old Dec 17, 2004 | 12:20 PM
Blue_Si03's Avatar
I'm riding on Progress springs and the instructions stated that I had to cut the bumpstops. I didn't know this until after I was finished with the install. I'm too lazy to redo the suspension so mine are uncut. The ride is good except over big bumps then you can tell the shock needs more travel in order to have a better ride quality.
Old Dec 18, 2004 | 11:22 AM
civicvtec1ps's Avatar
Default Re: (Blue_Si03)
Didn't cut mine.
Had S tech springs on oem shocks over 15000 miles.
Waiting for omni revised one
thecruzs2007@yahoo.com
Feb 27, 2010 12:56 PM
bopbop93030
Oct 28, 2008 07:02 PM
s2kc's
Honda S2000
Mar 28, 2006 01:52 PM
hondaracing1
Mar 28, 2005 09:32 AM
clutch33
Jul 31, 2004 09:19 AM
