boreing a ls block to 82mm safe?
i did a search and could not find what i was looking for. just want to know if anyone has bored .40 over and is it safe. i will be reving to 8.5k and want to make 200 whp thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx »</TD></TR><TR><TD CLASS="quote">i did a search and could not find what i was looking for. just want to know if anyone has bored .40 over and is it safe. i will be reving to 8.5k and want to make 200 whp thanks.</TD></TR></TABLE>
honda says that 82mm is the max for stock sleeves, so yeah, you should be fine
From: not riding any bandwagons in, massachusetts, usa
tensile stress rises at the square (2nd power) of engine rpm. 100=1000. youre asking a set of compromised cylinder walls to handle a LOT of sideloading and piston slap.
i wouldnt do it on a block that isnt posted, and i wouldnt do it on the stock 1.54 R/S ratio.. maybe .137" long rods.
ls blocks are plentiful. buying 82 mm pistons is an expensive way to find out.
