trailing arm bushings
Old Dec 12, 2004 | 04:47 PM
jhota's Avatar
Default trailing arm bushings
has anybody used these?
i'm considering doing a rear disc conversion on my wagon, and if i do i'll build a set of trailing arms and then swap them (so the car won't be off the road).
so, since my current bushings are shot, and any on junkyard arms would be shot, i'm trying to decide what to put in, and these look rather sweet.
i'm assuming the "recommended for track use only" text is to release them from liability: but any reasons you wouldn't use these on the street?
Old Dec 12, 2004 | 04:52 PM
insomniac791's Avatar
just get the mugen ones everyone I have talked to loves tehm. 250 bucks.....damn
Old Dec 12, 2004 | 04:54 PM
HatchBox's Avatar
Skoobie no more...
Default Re: trailing arm bushings (jhota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhota &raquo;</TD></TR><TR><TD CLASS="quote">
i'm assuming the "recommended for track use only" text is to release them from liability: but any reasons you wouldn't use these on the street?</TD></TR></TABLE>
they have no flexability, so your ride will definatly became pretty harsh.
Old Dec 12, 2004 | 09:06 PM
Rostr02's Avatar
Default Re: trailing arm bushings (HatchBox)
I will trade you my mugen ones if you buy me those
Honestly the ride is going to suck unless you are running a strictly track car get the mugen ones http://www.kingmotorsports.com
Old Dec 12, 2004 | 09:16 PM
KFBhonda's Avatar
i got the energy suspension bushings. they look nice but i haven't installed the arms yet so i dunno how they perform just yet. the real racing guys love the spherical bushings (from what i've read in forums) but i imagine for a street car they are pretty harsh. and the mugen ones prolly kick *** but cost a pretty penny like everything else mugen.
Old Dec 12, 2004 | 09:56 PM
eda6's Avatar
Default Re: (KFBhonda)
I got prothanes on a street car. The harsh ride doesn't really bother me because I avoid the shitty roads
Old Dec 12, 2004 | 10:54 PM
travis's Avatar
I wouldn't make the assumption that "recommended for track use only" is a liability issue. Frequently, the shop might actually know what they are talking about (I don't know if that's the case for the above shop, but I agree with their recommendation). Those RTA bearings function very differenty from the OEM application and will not perform as intended on a car that is setup for the street. They are also not maintenance free. These types of bearings will require regular lubrication and cleaning or they will wear quickly. Finally, you had better have a really good reason to spend $250 on your RTAs and I can't imagine what reason that might be for a street car other than bragging rights (not an accusation, I just can't think of any other reason).
Also, I suspect the ride quality is bogus. Frequently the assumption is made that "racing" parts always make any car handle better at the expense of ride comfort. That statement couldn't be more flawed. "Racing" parts are designed to work together, not one at a time, like "safety" parts. Not all safety parts will make you safe, and not all racing parts will improve performance and hurt comfort. I assume that concept came from the loss in comfort when using high spring rates, but I bet you could install these RTA bearings on a completely stock Civic and you would never feel the difference in comfort.
Here's a lot of very good information on RTA bushings that I won't take the time to retype: https://honda-tech.com/zerothread?id=493789
And some additional information on rear suspension dynamics: https://honda-tech.com/zerothread?id=606414
If you're going to spend $250 for some bushings/bearings, at least take the time to read what they're for.
Old Dec 13, 2004 | 08:57 AM
FakeJDMEF8's Avatar
are the ES ones any good???
Old Dec 13, 2004 | 09:31 AM
APEX CRX's Avatar
Default Re: trailing arm bushings (travis)
Good threads Travis thanks
Old Dec 13, 2004 | 10:54 AM
HT Chaplain's Avatar
Loved
Default Re: trailing arm bushings (APEX CRX)
ES
Old Dec 13, 2004 | 10:55 AM
crxgator's Avatar
Default Re: trailing arm bushings (HT Chaplin)
OEM Honda...
Old Dec 14, 2004 | 06:07 AM
FakeJDMEF8's Avatar
any other thoughts on ES TA bushings? i have the master kit and love it, but seems these are too hard and make the car unstable at higher speeds? im confused
rudebwoy
Suspension & Brakes
Sep 9, 2014 06:06 AM
beana
Mar 24, 2010 07:20 AM
The Destroyer
Nov 30, 2008 06:37 PM
JDMThoughts
Mar 21, 2005 03:41 PM
unknown0001
Sep 3, 2004 01:41 PM
