did b16 swap into 96 ex coupe, how do i hook up o2
like the title says i'm stuck, the o2 on the header is under the shift linkage and it has for wires, how many wires does the stock harness have, and how can i get them to be compatible.
stock one should have 4 wires...and im comfused. if you are asking why the O2 sensor cant be hooked up, its because the 02 on single cams 96-98 have the o2 sensor up top. you need to extend (wire crimps) the o2 sensor about 2 1/2 ft, and run it back down to where it should be. good luck
