what is the highest compression a b18b with a b16 head can take
Old Dec 12, 2004 | 12:26 PM
maxius19's Avatar
Default what is the highest compression a b18b with a b16 head can take
i plan on building a b18b block with a b16 head and i need to know how much compression it can take. and i also was wondering if it is possible to turbo a high compression engine.
Old Dec 12, 2004 | 01:00 PM
mmuller's Avatar
Mad Scientist
Default Re: what is the highest compression a b18b with a b16 head can take (maxius19)
i would say 12ish on pump gas with good tuning.
to the 2nd part; no not really feasible
Old Dec 12, 2004 | 01:04 PM
YwanaV8's Avatar
Im not to sure about the compression, sorry, But if you plan on boosting a high compression engine, be ready to buy a very good head gasket, good head studs and maybe bearings. -gabe
Old Dec 12, 2004 | 01:17 PM
non-VTEC's Avatar
if you wanted to run boost on a high compression engine......try to keep it under 11:1 and have it tuned really well.
Old Dec 12, 2004 | 01:22 PM
Denny Crane's Avatar
Default Re: what is the highest compression a b18b with a b16 head can take (YwanaV8)
11:1 and high boost? Maybe if you run C18 or methanol...or pump gas with a big bunch of water/alcohol injection, propane, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YwanaV8 &raquo;</TD></TR><TR><TD CLASS="quote">...maybe bearings.</TD></TR></TABLE>
How about genuine Honda bearings?
Old Dec 12, 2004 | 01:32 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
high compression and boost need very good tuning. this is the most important factor right next to building a bulletproof engine. it can be done with money, knowledge, and patience.
do a search for 'tony the tiger' and watch his vids and read about his setup. it's insane! 11.5:1 comp, 12 psi, ITBs, AEM EMS! he runs 94 octane though.
Old Dec 12, 2004 | 02:04 PM
Default Re: (MugenDude)
No one is going to run 20 psi with 11:1 on 94 octane and put out decent hp/bsfc, I don't care what kind of tuning has been done. Careful tuning will no doubt help, but you'll eventually hit the wall where nothing will make further improvements short of direct injection. I'd run a single digit CR.
Auto-ignition of fuel on the compression stroke under boost is the biggest barrier with that combo unless running race gas on the street isn't a big concern.
Personally, I'd get rid of the dome and run flat/dishtops, build squish/quench, dial in pth clearance, and crank up the boost.
Modified by Denny Crane at 3:14 PM 12/12/2004
Old Dec 14, 2004 | 08:18 PM
maxius19's Avatar
Default Re: (Denny Crane)
what do you think the highest compression and boost you can run off of 98 octane
Old Dec 14, 2004 | 08:44 PM
notstock93's Avatar
Default Re: (maxius19)
I wouldn't trust anything over 10:1 for a high-ish boost application. After that your starting to go into an area with diminishing returns.
Either way, your going to need to tune the holy-hell out of this engine so it doesn't blow up.
Old Dec 29, 2004 | 07:45 PM
maxius19's Avatar
Default Re: (notstock93)
so it is possible to do about a 10 to 1 compression and turbo it and still run 97 octan if i tune it extremly well and probaly have a fuel management system and have a boost controller
Old Dec 29, 2004 | 09:56 PM
notstock93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxius19 &raquo;</TD></TR><TR><TD CLASS="quote">so it is possible to do about a 10 to 1 compression and turbo it and still run 97 octan if i tune it extremly well and probaly have a fuel management system and have a boost controller </TD></TR></TABLE>
short answer - yes.
CALM_AS_A_BOMB
Mar 14, 2005 05:34 AM
mattcivic
Nov 28, 2004 04:41 PM
CircuitFG
Oct 22, 2004 10:38 PM
. o 69 o .
Aug 8, 2004 07:57 PM
Desperado
May 12, 2003 01:35 PM
