NEED FRONT HUB ASSEMBLY HELP!!!!
Old Dec 12, 2004 | 10:41 AM
ITR-00-1457's Avatar
Default NEED FRONT HUB ASSEMBLY HELP!!!!
Ok. The other day, with my caR in the air, I noticed that the front pass side wheel/hub assembly had a pretty good amount of play in it, about 4-5mm. Now I just replaced the wheel bearings about 3k ago and have not noticed any typical blown wheel bearing noises or felt any kinds of vibrations what-so-ever. All the bolts are tight and everything is where it is suppesed to be. Neither the upper or lower balljoints are lose, but if you grab rotor and rock it the play is just isolated to the actual hub assembly. The caliper and the dust shield stay fixed. I removed the axle nut to see if that would affect the amount of movement but it did not. It seem like the only thing left is the bearing, but I am not sure. Has this ever happened to anyone before? Any help would be much appreciated. Thanks.
Old Dec 12, 2004 | 11:09 AM
{Mineral Grey} ITR's Avatar
Default Re: NEED FRONT HUB ASSEMBLY HELP!!!! (ITR-00-1457)
Under hard braking does your steering wheel shake?
Old Dec 12, 2004 | 01:21 PM
Default Re: NEED FRONT HUB ASSEMBLY HELP!!!! ({Mineral Grey} ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Mineral Grey} ITR &raquo;</TD></TR><TR><TD CLASS="quote">Under hard braking does your steering wheel shake?</TD></TR></TABLE>
Nope, no shaking.
After a little more investigation, it looks like the bearing has come lose from the hub. I can see it moving around when I move the hub. can they jsut pop out of place?
Old Dec 12, 2004 | 01:27 PM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-00-1457 &raquo;</TD></TR><TR><TD CLASS="quote">can they jsut pop out of place? </TD></TR></TABLE>
Not if the bearing was pressed in correctly.
Old Dec 12, 2004 | 08:18 PM
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">Not if the bearing was pressed in correctly.</TD></TR></TABLE>
Well, how am I supposed to know that?
Old Dec 13, 2004 | 04:23 AM
Dan GSR's Avatar
Default Re: (ITR-00-1457)
I installed two new front wheel bearings 10k miles ago, and they are perfect.
I agree with Opie, it was most likely installation error, I can't see a new bearing, dying in 3k miles
Old Dec 13, 2004 | 07:42 PM
Default Re: (Dan GSR)
do you think that the bearing can just be pressed in again or am I gooing to need a new one?
Old Dec 13, 2004 | 07:48 PM
Dan GSR's Avatar
damage is probably already done
if you need someone to do a wheel bearing, ive done 6 already with my 20 ton press
Old Dec 14, 2004 | 02:28 PM
cool, thanks Dan. I will probably take you up on that offer.
Old Dec 14, 2004 | 02:32 PM
Willard's Avatar
https://honda-tech.com/zerothread?id=720159
Old Dec 14, 2004 | 02:38 PM
Default Re: (Willard)
cool, great pics and explaination.
Question - is it possible that the c-clip is either broken or out of place and that is why the bearing is so lose? and is it possible for the c-clip to be gone all together or just floating around in-between the hub and the bearing?
jBj
Apr 17, 2007 12:54 PM
valve79
Mar 23, 2005 05:02 AM
classciv
Aug 27, 2004 06:24 PM
Tyson
Feb 11, 2004 01:11 AM
ironcheftony
Sep 15, 2003 07:45 PM
