A/C Removal Weight Savings
Old Dec 12, 2004 | 10:31 AM
mgags7's Avatar
Default A/C Removal Weight Savings
I have searched my *** off and seen all kinds of different figures.....but none give a list of exactly what to take out. I will present my current list....feel free to modify it and tell me how much weight i will save.....
skdrcr posted a 32lbs weight saving
i want to retain my blower and everything for heat.....
To Remove:
Compresser
Condenser
Accumulator
All underhood lines
what else???
Old Dec 12, 2004 | 10:52 AM
SKDRCR's Avatar
Default Re: A/C Removal Weight Savings (mgags7)
That's pretty much it to my knowledge
Edit: Evaporator.
Remove the evaporator from the black evaporator box
and reattach the box to retain heat
Old Dec 12, 2004 | 10:53 AM
mgags7's Avatar
and you saved 32lbs like that, correct....
thanks
Old Dec 12, 2004 | 10:55 AM
SKDRCR's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">and you saved 32lbs like that, correct....
thanks</TD></TR></TABLE>
correct
above post edited
Old Dec 12, 2004 | 10:57 AM
BrokeLude's Avatar
Enjoy these next few months before summer gets here...
Old Dec 12, 2004 | 11:31 AM
mgags7's Avatar
i went this whole summer w/o ac dude....ill be fine....im a windows down person....still ride with em down now....
edit: how much does the evaporator weigh?? and any directions on which box to take it out of....not sure on that but i got the rest....
Old Dec 12, 2004 | 11:51 AM
SKDRCR's Avatar
edit: how much does the evaporator weigh?? and any directions on which box to take it out of....not sure on that but i got the rest....</TD></TR></TABLE>
It's underneath your glove box.
Just remove your glove box (six screws)
then you will see the box (next to the blower)
It's just about 8 screws and it will come out.
Evaporator weighs around 5-6 lbs.
Old Dec 12, 2004 | 02:09 PM
BrokeLude's Avatar
You're more of a man than I. I went without AC over the summer when I was a teenager, and it sucked. I can't imagine it now with these leather seats. When my nutz start sweating, it's time for some AC...
Old Dec 12, 2004 | 05:05 PM
mgags7's Avatar
yeah i have black leather too....its rough....
im still debating whether 32 lbs is worth it....but im leaning toward not....now i just need to get it charged.....
Old Dec 12, 2004 | 05:35 PM
hOndafienD 04's Avatar
32 lbs is worth it...especaially the lude is so heavy....you can take the hot weather
Old Dec 12, 2004 | 09:57 PM
95preludeSE's Avatar
Default Re: (hOndafienD 04)
I was wondering, what about removing power steering? The car isn't toooo heavy, and I've driven worse cars with no power steering at all. What kind of weight gains would go into that?
Old Dec 12, 2004 | 09:59 PM
bdb's Avatar
bdb
Once you remove the evaporator -- if you do, you'll need to connect the blower on the passenger side to the heater core directly under the center dash or you'll get misdirected air not picking up any heat.
Old Dec 12, 2004 | 10:01 PM
bdb's Avatar
bdb
Default Re: (95preludeSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95preludeSE &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering, what about removing power steering? The car isn't toooo heavy, and I've driven worse cars with no power steering at all. What kind of weight gains would go into that?</TD></TR></TABLE>
I took out my PS and installed a looped breather. The PS pump is the heaviest piece, but I'd guestimate around 10-15lbs of savings not to mention the free HP no PS yeilds.
Old Dec 12, 2004 | 11:16 PM
xludexgenx5's Avatar
Default Re: (bdb)
Sorrry for the newb quesiton, but on the PS why did you use a breather? as opposed to just looping it directly back to itself? thanks.
Old Dec 12, 2004 | 11:35 PM
@ries's Avatar
i took my ac out a couple weeks ago. fairly easy process. i just hope this summer isn't too harsh.
Old Dec 13, 2004 | 03:33 AM
Behan's Avatar
Default Re: (xludexgenx5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xludexgenx5 &raquo;</TD></TR><TR><TD CLASS="quote">Sorrry for the newb quesiton, but on the PS why did you use a breather? as opposed to just looping it directly back to itself? thanks.</TD></TR></TABLE>
Without the breather you are pushing air and fluid through the rack and lines, Its similar to just removing the belt.
With the breather, it makes it alot easier to turn the wheel.
Old Dec 13, 2004 | 03:50 AM
satan_srv's Avatar
Default Re: (Behan)
I don't remember the evaporator being THAT heavy...
Old Dec 13, 2004 | 10:08 AM
Default Re: (Behan)
ahh thanks for clearing that up.
Old Dec 13, 2004 | 10:35 AM
mgags7's Avatar
so if you do the whole breather thing its gonna be a lot easier to turn than the day i just took the belt off.....
say that day was a 10 harness to turn on a 1-10 scale....1 being with power steering.....rate this breather thing....
Old Dec 13, 2004 | 06:41 PM
mgags7's Avatar
bump for an answer to above:
rate the breather thing.....
1-10
10 being with just the belt off
where in between does the lines open with the breather fall? and what kind of store did you buy that breather at?
Old Dec 13, 2004 | 10:01 PM
bump for an answer to above: I'd like to know this too, I;ve been running no P/S ( just removed the belt )
Old Dec 14, 2004 | 05:06 PM
mgags7's Avatar
i im'ed the guy who did the breather thing, bump for more opinions, but i will post up what he said....
Old Dec 14, 2004 | 06:53 PM
somboa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">i im'ed the guy who did the breather thing, bump for more opinions, but i will post up what he said....</TD></TR></TABLE>
I think he said it was an 8 (with 1 being PS and 10 being beld removed) or something similar (ie not a noticeable difference).
What I'd like to know though is what happens if you completely remove everything? Ie bracket, pump, hose, rack, etc. How does that rate on the scale?
Old Dec 14, 2004 | 07:14 PM
bump for an anwser
Old Dec 15, 2004 | 05:00 PM
mgags7's Avatar
umm if you take the rack out you wont be able to turn...haha thats needed.....
i have driven a civic that was made with no ps and it still sucked! so im keeping mine.....my lude is my daily driver so im not about to wrench the wheel everywhere.....to much for me....
