wiring harness conversion???
Old Dec 12, 2004 | 09:25 AM
B20-Rex's Avatar
Default wiring harness conversion???
ok i have a big question and i did search . i would like to know if i can find a layout of the wireing harness freom a 89 dx civic hatch. i nees this cause i'm converting the car to obd1. also need 92 Si HB wiring harness layout. the reason for this is i'm swapping a obd1 JDM GSR from the 92 HB and just took all the wiring harness. if there is an easyer way to swap the GSR into an EF plz let me know b4 i take on such a task
the harness on the motor is obd1 and its a 94 GSR.
any help would be appreaciated. and greatly needed.
Old Dec 14, 2004 | 10:06 AM
B20-Rex's Avatar
Default Re: wiring harness conversion??? (B20-Rex)
Could sombody plz help me out ????? i'm in dire need
Old Dec 14, 2004 | 10:10 AM
CRX_Control's Avatar
use your original harness , its much easier, then if you get a conversion harness for the ecu then you can just add wires to your conversion harness . This way is much faster.
Old Dec 14, 2004 | 10:11 AM
Rywire's Avatar
Default Re: wiring harness conversion??? (CRX_Control)
I offer that job, let me know if you want your harness converted.
Ryan
Old Dec 14, 2004 | 03:56 PM
smart monkey's Avatar
I would first convert to MPFI and then get a jumper for OBD0-OBD1. lots easier to do this way. if you need a dx to mPFI harness I have a new hasport one for 199.00+exchange if not there is info online on how to convert but if not sure on your electrical skills then buying a premade harness makes it easier on you.
Old Dec 15, 2004 | 02:14 PM
B20-Rex's Avatar
well it's allready mpfi i am pretty sure. it had a Zc motor swap.
as for helping me i think its not possible sice i'm in Canada but thx for the help i will get a conversion harness.
Mike
Old Dec 15, 2004 | 04:01 PM
fast90hatch's Avatar
yup im gona have to be doing this soon. but i have to do (DPFI-MPFI/OBD0-OBD1 and wire it for vtec). its gona suck. but im gona have some help. (blownhatch90) IM not sure but i think that is it. well he is gona basiclly make me a harness. I have to send him my stock DX harness, and the new harness from the motor. then he is gona make it work for my ECU. but the thing is that i don't get is, he said i don't need to send him the chassis harness. well how is the New ECU gona fit into teh old chassis harness?? he said it is gona be plug and play when i get it back, but he did say that there are a few things i have to hook up inside the car. Has someone done this before. can you help me out on this. HOW WILL MY OLD CHASSIS HARNESS FIT INTO MY NEW PR3 OBD1 ECU??
Old Dec 15, 2004 | 06:59 PM
ThefirstPACT's Avatar
Default Re: wiring harness conversion??? (fast90hatch)
He is going to make the dpfi harness have everything the mpfi had. The obd 1 ecu is going to need a jumper harness, a obd1 ecu and a 4 wire o2 sensor(i think so havent done it...YET). Do lots or searching type in "dpfi mpfi" you will find tons of information.
Old Dec 15, 2004 | 07:48 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20-Rex &raquo;</TD></TR><TR><TD CLASS="quote"> if there is an easyer way to swap the GSR into an EF plz let me know b4 i take on such a task
Purchase one of these --&gt;Click Me
Send me your engine harnesses and I can convert them. Or you can do this option as well
------------------------------------------------------------------------------------------------------<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">I offer that job, let me know if you want your harness converted.
Ryan</TD></TR></TABLE>------------------------------------------------------------------------------------
Either way, this swap is probably one of the easiest out there in regards to wiring when you use the conversion harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast90hatch &raquo;</TD></TR><TR><TD CLASS="quote">yup im gona have to be doing this soon. but i have to do (DPFI-MPFI/OBD0-OBD1 and wire it for vtec). its gona suck. but im gona have some help. (<FONT COLOR="red">Blown90hatcH</FONT>) IM not sure but i think that is it. well he is gona basiclly make me a harness. I have to send him my stock DX harness, and the new harness from the motor. then he is gona make it work for my ECU. but the thing is that i don't get is, he said i don't need to send him the chassis harness. well how is the New ECU gona fit into teh old chassis harness?? he said it is gona be plug and play when i get it back, but he did say that there are a few things i have to hook up inside the car. Has someone done this before. can you help me out on this. HOW WILL MY OLD CHASSIS HARNESS FIT INTO MY NEW PR3 OBD1 ECU??</TD></TR></TABLE> Because I will be using one of my OBD0-1 conversion harnesses for the ecu.
<FONT COLOR="Blue"><FONT SIZE="3">Don't forget my sale going on here too.</FONT></FONT>
Modified by Blown90hatcH at 10:38 AM 12/16/2004
Old Dec 15, 2004 | 09:24 PM
silent-chris's Avatar
Default Re: wiring harness conversion??? (Blown90hatcH)
this is what im running in my obd1 B16 in my crx http://www.boomslang.us/obd0.htm and http://locashracing.com/store/...id=58 very quick shipping from both companies and if you order the lo cash harness dont forget the option for the distributor good luck
Old Dec 16, 2004 | 11:09 AM
Default Re: wiring harness conversion??? (silent-chris)
OH ok i got it now... Sorry i got your name worng!! i understand now.
Old Dec 17, 2004 | 08:37 AM
B20-Rex's Avatar
ok now i have a problem. i allready got all the wiring in the car. exept the rear past the rear seats. i need a diagram for the harnesses. can somebody plz help here?
jordy75
Jun 10, 2010 01:59 PM
vtechjunkie
Mar 11, 2009 07:31 PM
Chester Rumble
Feb 12, 2007 09:23 PM
shimtaw
Jan 5, 2007 05:41 AM
91teg
Sep 1, 2004 06:06 PM
