Auto stuck in gear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx »</TD></TR><TR><TD CLASS="quote">check the adjustment cable</TD></TR></TABLE>
When you pull the plate off underneath (some 10mm bolts), there is a pin that holds the cable in place onto the transmission. Make sure that is not stuck on something, as I've seen that happen before.
Otherwise, make sure it's not something stupid/simple like putting the key into the shifter console and unlocking it and allowing you to move the shifter.
