4-2-1 turbo mani design??
I've been toying with some new ideas for a turbo mani, and one of them is to go with a 4-2-1 design, instead of having all 4 runners merge into one collector. I haven't seen any out there that have this kind of setup, but would that be because its a bad idea, maybe some issues with flow etc, but I think it would be interesting to see a manifold like this. Any thoughts on this kind of design?
The reason you don't see them out there is because it's hard enough to get a 4-1 collecter in that small of an area, with the necessary elbows...add in a 2-1 collector and a few more elbows that it will likely take to snake around to and from it... and you'll probably be cuttign some body work out of the way.
i thought about this as well. here pretty soon im going to get another civic just to blow up all the time. i have so many single cam motors sitting around i have a bunch of STUPID idea's in my head....i just want to blow up a bunch of stuff to see what happens with differnt things...and differnt turbo designs and such.
The manifolds I build are sort of a truncated 4-2-1 design. the 4-2 isn't really a true merge but it's pretty smooth. good for tight spots and tight wallets
Modified by Bailhatch at 5:30 PM 12/12/2004
Check the bergenholtz car or the sand rail we did for saturn motor sports i posted up the pics way back when
there are beneftis but sizing and length are going to be very crucial
I thought the point of using a divided inlet turbine housing was for it to function like the second collector? Basically, you would build two seperate 2 into 1 collectors and then have the turbo function as the final 2 into 1 collector.
Sully90SiPrelude
Mar 15, 2007 02:37 PM
