turbo project, input wanted
Old Dec 12, 2004 | 07:25 AM
justinau's Avatar
Default turbo project, input wanted
im plan on turboing my crx si i got a y8 vtech head on it and in puting new bearings rings y8 pistons and rods and a trilpe layer steal headgasket on it. i gotta t28 turbo turboxs bloww off valve and im using a vafc2 for fuel management with eclipse injectors. do i have every thing needed for my project and has anyone ever had this setup before any input eill help. thanks. pics too if possible
Old Dec 12, 2004 | 08:04 AM
dr_latino999's Avatar
Default Re: turbo project, input wanted (justinau)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinau &raquo;</TD></TR><TR><TD CLASS="quote">I am planning on boosting my CRX. I have a Y8 Head, and I am going to do a bottom end rebuild. I have a T28, TurboXS blow off valve, and I'm using a VAFC2 for fuel management with 440cc injectors. Do I have everything needed for my project?</TD></TR></TABLE>
1) [URL=www.homemadeturbo.com]Turbo Setup[/B]
2) It is a known fact that the D16Y blocks have had bearing issues; some have them, some don't. Predominately they do.
3) Look into better fuel and timing managment if you don't want everything to fail and we have to see you here in two weeks "Why Did My Motor Explode?". Turboedit for OBD-0 (FREE), Uberdata (FREE), Chrome (FREE), and Hondata (Not so free) for OBD-1.
4) If you are using stock parts on the rebuild, you still will have the ~200 hp limitation on the stock rods before the tend to grenade. This isn't a set rule, but if you want more power out of this NA engine, look for some forged internals.
Old Dec 12, 2004 | 08:21 AM
b18-c-rx's Avatar
Default Re: turbo project, input wanted (dr_latino999)
you might want to pop in an IC so you can run higher boost, and make sure that you have a wastegate (if it's not internal)
then you need to worry about cooling tubing etc. check out homemadeturbo
94c1v1cex
Mar 10, 2008 10:07 AM
chippy
Dec 2, 2004 02:20 PM
dan89crxsi
Jul 2, 2004 09:48 AM
98silvercivicEX
Feb 15, 2004 12:27 PM
