Oil leak...HELP
Old Dec 12, 2004 | 05:49 AM
evad's Avatar
Default Oil leak...HELP
Ok i have a oil pan gasket leak. I have replaced the oil pan kasket 3 times and it still leaked from the driverside front corner. So i bought a new oil pan and gasket and that bastard still leaks. I don't know what to do. I'm pissed. Oh and i have a B16a. SUGGESTIONS!!!!!!!!!!!!!
Old Dec 12, 2004 | 06:15 AM
donuttes's Avatar
did you check the oil pan flange for bends
Old Dec 12, 2004 | 06:45 AM
evad's Avatar
Default Re: (donuttes)
Sorry but WTF is that?
Old Dec 12, 2004 | 09:03 AM
b18-c-rx's Avatar
Default Re: (evad)
the thing on the engine that your pan gasket mates to - does it have bends
Old Dec 12, 2004 | 03:28 PM
evad's Avatar
Default Re: (b18-c-rx)
oh i don't know......i'll take everything apart again and check
thanks
Old Dec 12, 2004 | 03:34 PM
drdisco69's Avatar
Default Re: (evad)
And did you use Hondabond or any kind of sealant on it? See this thread:
https://honda-tech.com/zerothread?id=1069442
Old Dec 12, 2004 | 07:16 PM
evad's Avatar
Default Re: (drdisco69)
Yes i used honda bond in the corners. Does anyone think that the block could actually be warped??????I guess i'll just have to do it again.
Old Dec 12, 2004 | 07:51 PM
RedRocketCRX's Avatar
Default Re: (evad)
i dont have a b16, but i do got the same problem on my a6. im thinking its the main seal on my cuase im going through a quart a week on my car and the oil is all around the crank pulley. ive changed the gasket used silocone and checked to see that the pan and the flange wasnt warped (learned to do that after changing the gasget on my friends car 4 times) every thing is good. dont now for sure if its the main seal havent riped it apart to check.
Old Dec 13, 2004 | 08:54 AM
evad's Avatar
Default Re: (RedRocketCRX)
ok after looking at the oil leak a little more closely, i have decided that the oil is leaking from the oil pump housing. so this means that it is probably the main seal....right?!
Old Dec 13, 2004 | 09:08 AM
Akira54's Avatar
Default Re: (evad)
yes
Old Dec 13, 2004 | 09:22 AM
RCautoworks's Avatar
Default Re: (evad)
For future installation tips, when you do you oil pan gasket you need to hammer the rivets out of the oil pan. When you tight in you oil pan it makes a rivet that looks like this __/\_ , well every time you put on a new gasket and tight in it down, those rivets will rip the gasket.
Old Dec 13, 2004 | 09:48 AM
evad's Avatar
Default Re: (90blackcrx)
i'll remember that thanks
Old Dec 13, 2004 | 10:59 AM
evad's Avatar
When i go to replace the main seal am i going to have to drop the oil pan, or can i just remove the timing belt, timing belt cover, and oil pump housing and go from there???????
trooper0641
14
Oct 11, 2005 07:11 PM
mf RENO
Aug 31, 2004 11:06 AM
Mattyg2
Aug 28, 2004 04:50 PM
MR. ARIZONA
Sep 3, 2003 05:04 PM
d0nkeyxPunch
May 10, 2002 04:01 AM
