192k miles on my LS motor.. should i get LS/VTEC?
Old Dec 12, 2004 | 01:02 AM
All Motor EH2's Avatar
Default 192k miles on my LS motor.. should i get LS/VTEC?
I have a 1992 integra LS with 192k miles on the engine. Would it be worth it to put a vtec head and do LS/Vtec? Or should I just try to find a newer LS engine with less miles?
Thanks.
Old Dec 12, 2004 | 01:35 AM
FR-MOB: ThE bEe GuY's Avatar
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (All Motor DA)
Find one with less miles
Old Dec 12, 2004 | 01:49 AM
iH8RICERZ's Avatar
how much money do you plan on spending?
Old Dec 12, 2004 | 02:54 AM
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">how much money do you plan on spending? </TD></TR></TABLE>
Well.. I'm trying to spend less then $2000 if possible. That's one of the biggest reasons I am looking into LS/Vtec is because it's supposed to be a fairly cheap project. Even with me buying a newer LS engine it will still be cheaper then getting a GS-R or type-R engine.
Well, now my new question is, if i get a newer LS engine (94+) would it bolt right in my car? Will any modifications need to be made? I would actually rather have a seperate LS engine to work on outside of the car. That way I can drive and have the other LS engine to build up and work on without having to remove my engine all the time.
Old Dec 12, 2004 | 05:08 AM
Rod.'s Avatar
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (ThE bEe GuY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY &raquo;</TD></TR><TR><TD CLASS="quote">Find one with less miles </TD></TR></TABLE>
Old Dec 12, 2004 | 10:43 AM
.Eddie's Avatar
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (redturbocivic)
its better to have a spare engine to work. And yes a 94-01 b18b will fit in your integra, you just have to reuse mounts and it will bolt right up.
Old Dec 12, 2004 | 11:13 AM
VN712's Avatar
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (killerb20zallmotor)
dont' mind them....with 2 grand ls/vtec is a doable. You are basically rebuilding your whole block and replacing your head.....milage is poop in this case as long as there is no major damage
Old Dec 12, 2004 | 11:21 AM
ProJectCvic's Avatar
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (B20ZLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20ZLS &raquo;</TD></TR><TR><TD CLASS="quote">dont' mind them....with 2 grand ls/vtec is a doable. You are basically rebuilding your whole block and replacing your head.....milage is poop in this case as long as there is no major damage</TD></TR></TABLE>
yea man...totally agree..rehone, new/ higher cr piston, stronger rod, stronger bolts, new bearing, new head, gasket and you basically have a new motor. You might have to wait on getting a shorter gear tranny untill you have some more money though.
Old Dec 12, 2004 | 05:33 PM
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (ProJectCvic)
I was thinking of getting a b16 tranny pretty soon here. A friend of mine is selling one to me for $200 so I think i'm going to grab that one.
Old Dec 12, 2004 | 05:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">
yea man...totally agree..rehone, new/ higher cr piston, stronger rod, stronger bolts, new bearing, new head, gasket and you basically have a new motor. You might have to wait on getting a shorter gear tranny untill you have some more money though.</TD></TR></TABLE>
So, you think it would be ok to keep this 192k mile motor and do the LS/Vtec? I'm just worried that the motor will crap on me in a year or two with that many miles.
Old Dec 12, 2004 | 05:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All Motor DA &raquo;</TD></TR><TR><TD CLASS="quote">
So, you think it would be ok to keep this 192k mile motor and do the LS/Vtec? I'm just worried that the motor will crap on me in a year or two with that many miles.</TD></TR></TABLE>
before you make any decision, make sure that the walls are not crack, etc...don't worry much if there is a bit of scaring oh the wall. They can be rehone/ overbone
Old Dec 12, 2004 | 05:44 PM
BTW....192k is not that bad on a honda motor given that you don't abuse it. I rip apart a motor that was 233K and it had bearly any damages to the wall....it depends though
Old Dec 12, 2004 | 05:53 PM
stasi's Avatar
Leak down and compression tests are key.
I'd say do a rebuild first.
Old Dec 12, 2004 | 05:56 PM
sleevedgsr's Avatar
Rebuild the 192k LS dont let her go to waste like that! So much can be done!
Old Dec 12, 2004 | 06:10 PM
MugenRacerX's Avatar
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (boosted95teg)
first off im all for ls/vtec im building one rite now,you have 2k to spend I have seen entire gsr swaps for 1800 seems to be the going price now...or rebuild your motor and go ls/vtec, whatever you do dont just slap the vtec head on or whatever parts original that were just holding on are gonna be subject to more forces, that cant be good.
urbanracer.com
thepartstrader.com are 2 places i have seen gsr swaps for 1800 or even a built ls/vtec
Old Dec 12, 2004 | 06:25 PM
Default Re: 192k miles on my LS motor.. should i get LS/VTEC? (MugenRacerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenRacerX &raquo;</TD></TR><TR><TD CLASS="quote">first off im all for ls/vtec im building one rite now,you have 2k to spend I have seen entire gsr swaps for 1800 seems to be the going price now...or rebuild your motor and go ls/vtec, whatever you do dont just slap the vtec head on or whatever parts original that were just holding on are gonna be subject to more forces, that cant be good.
urbanracer.com
thepartstrader.com are 2 places i have seen gsr swaps for 1800 or even a built ls/vtec</TD></TR></TABLE>
I'd rather build it up myself. Thanks
Modified by All Motor DA at 9:34 PM 12/12/2004
baam
Sep 14, 2005 09:38 AM
team703
Apr 4, 2004 10:28 AM
1hotintegra
Jun 12, 2002 09:48 AM
integra81
Oct 18, 2001 07:10 PM
