Which pistons to get??
Old Dec 11, 2004 | 04:04 PM
getzy3's Avatar
Default Which pistons to get??
MY friend had zex hooked up to his b16a2 and burnt a piston. So instead of spending a lot of money on aftermarket pistons he might go w/ type r pistons. Will B16b and B18c5 both work?? Which would be best??
Old Dec 11, 2004 | 07:37 PM
RedlinedVTEC's Avatar
Default Re: Which pistons to get?? (getzy3)
The ctr or itr pistons can be used, but the rods will need to have 1mm milled from each side of the connecting end of the rods.
The ctr pistons will yield higher compression than the itr pistons and in either case if your friend still wants to use nitrous he's better off going with different pistons that will yield a lower comopression.
Old Dec 11, 2004 | 09:28 PM
110 South's Avatar
Any OEM piston, being that they are cast, can also melt or burn under the extreme temps when using nitrous. Therefore, the only way to minimize this is to use a forged unit. By using a ITR piston you are not gaining any added strength and by the same token, a CTR piston will achieve a higher compression level, which in turn will possibly create more issues when used with nitrous. I've had good results in the past using 10.5:1 forged pistons in a B16A block, while running up to a 100 shot of nitrous. In conjunction, the fuel management used helped to dial in the nitrous and tune the motor around the configuration.
For a relatively stock ecu config(i.e. VAFC or other entry level fuel controller), you can probably get away with it as well.
-Brandon
Old Dec 11, 2004 | 10:47 PM
Turbo(less)DB8's Avatar
Default Re: Which pistons to get?? (110 South)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 110 South &raquo;</TD></TR><TR><TD CLASS="quote">Any OEM piston, being that they are cast, can also melt or burn under the extreme temps when using nitrous. Therefore, the only way to minimize this is to use a forged unit. By using a ITR piston you are not gaining any added strength and by the same token, a CTR piston will achieve a higher compression level, which in turn will possibly create more issues when used with nitrous. I've had good results in the past using 10.5:1 forged pistons in a B16A block, while running up to a 100 shot of nitrous. In conjunction, the fuel management used helped to dial in the nitrous and tune the motor around the configuration.
-Brandon</TD></TR></TABLE>Agreed, the last thing you want with nitrous is hight compression. If I were you, I'd spend the little extra for an aftermarket piece with a lower comp.
Old Dec 12, 2004 | 08:03 AM
getzy3's Avatar
So he should get aftermarket lower compression pistons?? Which brand?? We arent sure what went wrong w/ tyhe motor. Something went bad in the fuel system. He was running a zex 50 shot and only ran it once, leaned it out and burnt a hole in the piston.
Old Dec 13, 2004 | 05:29 AM
getzy3's Avatar
Anyone??
Old Dec 13, 2004 | 06:31 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by getzy3 &raquo;</TD></TR><TR><TD CLASS="quote">So he should get aftermarket lower compression pistons?? Which brand?? We arent sure what went wrong w/ tyhe motor. Something went bad in the fuel system. He was running a zex 50 shot and only ran it once, leaned it out and burnt a hole in the piston.</TD></TR></TABLE>
Are your sure it was hooked up correctly?
Old Dec 13, 2004 | 08:04 AM
getzy3's Avatar
Default Re: Which pistons to get?? (tgreaves)
well i have no clue of how to hook up it up so i wasnt able to help. He is pretty sure it was hooked up right though. What could have been wrong in hooking it up to make that happen?? If anyone knows it would be great so it doesnt happen again!!
Old Dec 13, 2004 | 08:08 AM
tgreaves's Avatar
If you have the vacuum lines going to the manifold and to the fpr reversed that probably would do it.. On a 55 shot, any stock motor should be able to handle that.. I ran a Zex 55 shot dry on a crx hf motor which is the weakest motor out there and I did it for a long time..
Old Dec 13, 2004 | 10:58 PM
110 South's Avatar
I hear ya on that one. I've seen 80 shot dry on a stock B16 at it didn't burn the piston up. Keep in mind that although you are using a 50 shot jet, by the time it enters the intake plenum and it distributed into each runner, then mixed with fuel and into the combustion chamber; it is a little less. Therefore, a 50 shot will not get you 50hp, but maybe 10-15 at the wheels.
-Brandon
Slickrick936
Feb 24, 2011 12:39 PM
itr1244
15
Mar 29, 2009 05:46 PM
lickety_britches
Mar 21, 2008 07:31 PM
1993gsrcivic
Nov 14, 2007 08:11 AM
truazn4lyfe
Jul 4, 2007 06:37 PM
