NGK Spark Plug Wires ... F22B2 --> H22A
Old Dec 11, 2004 | 03:57 PM
Stoich EG2's Avatar
Default NGK Spark Plug Wires ... F22B2 --> H22A
I have new spark plug wires for my F22 non vtec. I just blew the motor. I was wondering if I can use the wires from my F22 on my H22 since i just bought them. thanks guys.
edit: they are NGK R-8 wires.
Old Dec 11, 2004 | 06:14 PM
TakeiTeg's Avatar
Default Re: NGK Spark Plug Wires ... F22B2 --> H22A (Advan06)
from my experience nop they won't fit..seems like the f22 is shorter.
so you'll need to get some h22a's.
Old Dec 11, 2004 | 08:33 PM
Stoich EG2's Avatar
Default Re: NGK Spark Plug Wires ... F22B2 --> H22A (TakeiTeg)
Prelude - Custom performance wire set with ferrite magnetic core. Wire Length No.1 653mm 25.71in. Wire Length No.2 573mm 22.56in. Wire Length No.3 433mm 17.05in. Wire Length No.4 353mm 13.9in. Coil Wire Length = 364mm 14.33in.
Accord - Custom performance wire set with ferrite magnetic core. Wire Length No.1 709mm 27.91in. Wire Length No.2 589mm 23.19in. Wire Length No.3 569mm 22.4in. Wire Length No.4 429mm 16.89in. Coil Wire Length = 384mm 15.12in.
Accord ones are longer... is there anything that has to do with the m4d VtAK that wont make it work?
Old Dec 11, 2004 | 08:54 PM
v4lu3s's Avatar
RTFM
it may not be the wire length being referred to but the part aht plugs onto the sparkplugs that is shorter.
williamcollins
Jul 8, 2017 01:24 PM
jdmsir4dr
Apr 25, 2013 08:33 PM
silver hatch
Mar 29, 2005 01:52 PM
johnclaunch
Aug 18, 2004 03:06 PM
Revi
May 31, 2004 01:01 PM
