lil' bit of everything
Guest
Posts: n/a
-90-91 curved top cluster w/tach with matching cluster cover and the buttons in the cover(traded to 45psi)
-P05 manual ecu
-p28 board with no case that was socketed(not sure if it works)
-OEM GSR strut bar black mint condition
-2 d15b7 dist's
-d16y7 dist(needs a rotor)
-d16z6 complete shortblock has tapped oilpan(leaks oil from oilpump or main seal)NO SHIPPING
-D15B8 CX engine harness
-Stock d15/d16 OBD1 fuel rails(blinging CNC'd ones )
-HF mani heat sheild
-OBD0 ecu harness and connectors(about 8-10 inches of wiring)
I'm located in Neenah WI if anyone is local or nearby.
always looking for good 1.5 shortblocks!!
-P05 manual ecu
-2 d15b7 dist's
howell839
Mar 24, 2019 10:29 AM
