ecu question
Old Dec 11, 2004 | 12:10 PM
GoFastMotorSports's Avatar
Default ecu question
So right now I got a 90 SI ecu with turbo edit running my turbo y7, I have a sleeved z6 I am throwing in this week, here is my question. Can I use a obd0 b16 ecu??? I wanna get one and setup my turboedit program on it. I wasnt sure cause of the obvious difference of 2 cams to 1. Thanks in advance
Old Dec 11, 2004 | 02:19 PM
Default Re: ecu question (GoFastMotorSports)
bump for an answer
Old Dec 11, 2004 | 02:34 PM
Redline130's Avatar
I don't see why it wouldn't work. I've used a pr3 on a mini-me before, ran a little rich, but worked fine.
Old Dec 11, 2004 | 02:36 PM
mrspeaker's Avatar
Default Re: ecu question (Redline130)
Yeah it'll work ,,but run pig rich..
Although I dont see why there would be a problem since you'll have uberdata to tune it....
Old Dec 11, 2004 | 02:42 PM
Default Re: ecu question (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it'll work ,,but run pig rich..
Although I dont see why there would be a problem since you'll have uberdata to tune it....</TD></TR></TABLE>
uberdata is obd1....i hae turboedit and I opened up a bin file for the pr3 ecu and is has fuel tables and stuff for 2 cams. So i am a little confused
Old Dec 11, 2004 | 02:45 PM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoFastMotorSports &raquo;</TD></TR><TR><TD CLASS="quote">
uberdata is obd1....i hae turboedit and I opened up a bin file for the pr3 ecu and is has fuel tables and stuff for 2 cams. So i am a little confused</TD></TR></TABLE>
Im sorry ..I meant turboedit..
Old Dec 11, 2004 | 03:41 PM
Jaker's Avatar
The PR3 ECU is for the 1st generation DOHC Vtec motor. Therefore, there's fuel and ignition maps for the low cam and the high cam.
Old Dec 11, 2004 | 04:09 PM
Default Re: ecu question (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">
The PR3 ECU is for the 1st generation DOHC Vtec motor. Therefore, there's fuel and ignition maps for the low cam and the high cam.</TD></TR></TABLE>
Yes I understand that. But I read that somebody used a pr3 with turboedit to control his sohc vtec turbo motor. I was trying to see how this was possible
Old Dec 11, 2004 | 04:27 PM
Jaker's Avatar
A SOHC Vtec has the same high and low cam fuel and ignition tables as the DOHC.
Old Dec 11, 2004 | 04:34 PM
Ok,so than I will tune it just like I would tune my sohc one. Thanks
strawberry
10
Dec 14, 2007 11:47 AM
JDmspoon22
18
Sep 4, 2007 09:09 AM
dwerpk
Dec 19, 2006 01:17 PM
Fezzie
Aug 2, 2006 03:58 PM
GoFastMotorSports
Dec 11, 2004 02:19 PM
