soldering help lol...
Old Dec 11, 2004 | 09:08 AM
RTW DC2R's Avatar
Default soldering help lol...
Trying to rewire my injector harness...first I have to extend the wires, then attach the clips on the newly extended wires. I started to extend the wires, but my soldering skills arent the best and I need to know if this is safe or not. i like to keep it ghetto, but Im wondering if this is too ghetto haha. what do you think? keep the wiseass comments to yourself please
Old Dec 11, 2004 | 09:18 AM
Bbasso's Avatar
Default Re: soldering help lol... (RTW DC2)
thats fine, as long as you can't pull them apart.
MattD@Stoptech's Avatar
A bit too much solder for my taste, but it l00ks fine. (You did heat up the wires and not the solder, ri? That way the solder is drawn into the wires for a much better connection.)
Now go get some shrink tubing before you connect the other end of the extension to anything.
Old Dec 11, 2004 | 09:22 AM
B2FiNiTY's Avatar
Default Re: soldering help lol... (El Pollo Diablo)
You need heatshrink tubing!!
RTW DC2R's Avatar
nice!! I thought I mutilated it but I guess Im better than I thought w00t!
but I wish I had a 3rd hand.
will electrical tape work as "shrink wrap"? thats how it was done before and seemed to protect it fine.
Old Dec 11, 2004 | 09:26 AM
Reid's Avatar
Global Moderator
Something I like to do, but isn't necessary is to twist the wires together before soldering them. After twisting the wires together they are strong enough to hold together without the use of solder (though they will still be soldered). I like to make it so that the soldered joints do not have to take all of the force.
Maybe I'm just **** though.
Old Dec 11, 2004 | 09:27 AM
Reid's Avatar
Global Moderator
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">will electrical tape work as "shrink wrap"? thats how it was done before and seemed to protect it fine. </TD></TR></TABLE>
Always use heat shrink.
Electrical tape can get old, unravel and turn into a big slimy mess.
Heat shrink will never unravel over time. Do it right the first time.
Old Dec 11, 2004 | 09:51 AM
RTW DC2R's Avatar
thanks reid and everyone else.
sucks doing this stuff by myself for the first time with no help so Im glad you guys are around!
Old Dec 11, 2004 | 09:55 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">sucks doing this stuff by myself for the first time with no help so Im glad you guys are around!</TD></TR></TABLE>
Just make sure you have good, solid connections and heatshrink to cover any exposed wire.
I don't want to see you start a thread about how your ITR burned to the ground.
Reid - who remembers when a local ITR's carpet caught on fire due to a shoddy MSD install...
Old Dec 11, 2004 | 09:58 AM
nightrider's Avatar
looks like there's too much solder, but it's fine. you'll be a pro soon. btw, heating up the wire never works for me.
Old Dec 11, 2004 | 10:05 AM
Im_In_There's Avatar
Default Re: soldering help lol... (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Something I like to do, but isn't necessary is to twist the wires together before soldering them. After twisting the wires together they are strong enough to hold together without the use of solder (though they will still be soldered). I like to make it so that the soldered joints do not have to take all of the force.
Maybe I'm just **** though. </TD></TR></TABLE>
mikestypeRR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">nice!! I thought I mutilated it but I guess Im better than I thought w00t!
no electrical tape gets old and starts to get all shitty after a while.... heat shrink tubbing works best and makes for a nice looking finish to the project.
Old Dec 11, 2004 | 11:18 AM
RTW DC2R's Avatar
the "heating the wire" method is not working so Im just doing what Ive been doing.
**** thieves for cutting my god damn harness!!!
Old Dec 11, 2004 | 11:26 AM
RTW DC2R's Avatar
what can happen if there is too much solder??? is that a bad thing? does it ruin the connection? if I put any less I feel like Im not putting enough and it doesnt connect all the copper wires.
Old Dec 11, 2004 | 11:27 AM
Bbasso's Avatar
Just use enough that when it cools you can not pull them apart
Old Dec 11, 2004 | 11:29 AM
Padawan's Avatar
Darth ModerVader
If you live anywhere near the GWB, you're more than welcome to stop by my house with your setup the way it is now, and I'll help you clean everything up. Once we're finished, they'll look like they came from the factory.
Old Dec 11, 2004 | 11:34 AM
Bbasso's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If you live anywhere near the GWB, you're more than welcome to stop by my house with your setup the way it is now, and I'll help you clean everything up. Once we're finished, they'll look like they came from the factory. </TD></TR></TABLE>
He got no motor...
Old Dec 11, 2004 | 11:37 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Bbasso)
Hmm... That might make the trip a little tough, huh. Ah well, the offer stands anyway.
Old Dec 11, 2004 | 11:39 AM
RTW DC2R's Avatar
thanks for the generosity but unfortunately as Rob stated, I have no motor. maybe when all is said and done I can swing by to clean some things up.
Old Dec 11, 2004 | 02:27 PM
sander's Avatar
2.7(p/t)
Youll usually want to have a solid connection before soldering (twist, then solder) and then add a little bit of solder to "lock" the connection (for lack of a better word).
You can tell a good solder connection from a bad one, if you heat up the wire and not the solder to make the connection it will be a nice shiny connection (good).
If you heat up the solder and not the wire it will be a "cold" joint. and will be almost satiny and dull looking, and extrememly weak (bad).
shiny = good
dull = bad
-s
Old Dec 13, 2004 | 07:34 PM
stumpyf4's Avatar
Default Re: (sander)
My technique;
1) Preheat the soldering iorn.
2) Twist the wires together.
3) 1 drop of liquid flux at the joint.
4) Heat the wires, flux will start to evaporate.
5) Stab in the solder from the opposite side as the soldering iron.
The solder will wick into the strands of the wire... you'll know when you do it right. Liquid flux is the way to go, the flux core stuff isn't so hot.
djgruesome
Jul 3, 2006 01:37 AM
hennessy
Audio / Security / Video
May 4, 2006 01:51 PM
enhancedCL9
Feb 10, 2004 10:51 PM
Z6REX-SI
Jan 5, 2004 09:22 AM
